Pole Barn Kit - Northeast Sources
   / Pole Barn Kit - Northeast Sources #1
Spudland_Dave
Veteran Member
Maine
Deere 3520 Cab, Deere F935
I'm in the process of deciding what I want for a garage/shop.. something on the order of a 30x40 building of some sort...either Pole or Stick built. Probably the final decider will be cost.. I'm planning on this being a 100% DIY project no matter which way I go... I've been googling for 2 days but cant find any sources in the Northeast?
Where in the Northeast (Maine or NH Specifically) can a person find sources for a Pole Building kit?
Anybody know of anything?
   / Pole Barn Kit - Northeast Sources #2
Menards ??
actually, if u have an idea of what u are going to build , and can buy the rafters, the rest is just lumber and screws and nails and tin - available in a lot of places.....
   / Pole Barn Kit - Northeast Sources #3
You can take your basic building plan to an engineered truss manufacturer. They will design and build a truss that meets your needs for your locale. It would be good to have some guidelines in mind like pitch, width of eaves, gable end eaves or not, snow load rating, attic space or not, scissor truss needed, etc. They will probably tell you 99% of what you really need to know. This does not add to the cost, it's the way contractors buy trusses for their projects.
Menards ??
No Menards around here...
I know its not exactly rocket science but the whole allure to me of a Pole building was to get something dropped off as a kit and with little/no cutting or head scratching I could just start assembling....quick, easy, and theoretically cheaper.
If I have to do all the calculations, running around for materials, cutting, etc... I may as well just go down to my local lumberyard with a rough pencil sketch with rough numbers of what I want and they can drop everything off I need for a stick built.
   / Pole Barn Kit - Northeast Sources #5
Spudland_Dave - The lumber yard could no doubt do the same for pole barns if they will do that for stick built.
Are you on the fence about which type of construction you want?
Are you up in The County?
Dave.
Dave.
Yeah I'm kinda on the fence about what I want.... With little ones HOPEFULLY on the way, we dont want to spend a fortune in one shot...I've read MANY sites saying that Pole barns go up quick & cheap, but once you insulate, finish, etc... them they end up at about the same price...which works for me. Cheap now to get a structure up & sealed up, and I can just do the rest little by little myself as funds allow.
Things that are certian regardless of build type....Vinyl Siding - MUST Match the house exactly. Roofing..she wants it to match the house (Expensive asphalt shingles) and I want steel... other then that, only other requirements are it must be weather tite... :)
Both my wife and I are originally from the County...still go up at least every other month...now we're "down south" like everyone else from up there.
   / Pole Barn Kit - Northeast Sources #7
I sort of sensed you hadn't decided. I am all for vinyl siding, I have painted and stained enough! Have better things to do. I am not saying it's the prettiest thing, but it is practical.
I guess the major difference in the starting out price would be that a pole barn provides it's own foundation so to speak. I have seen people bank 1 1/2" clean stone up against the bottom board pressure treated lumber to keep the wind and critters out, then go back and pour a slab later - or not.
I don't know of any practical away to stick build without a slab or frost wall to start with.
You'll sort it out over time. Good luck on those Little Ones!
Dave.
   / Pole Barn Kit - Northeast Sources #9
Pole is stick built, the sticks are just put together slightly different. The "kits" are essentially most of the material packaged and delivered together. You still have to cut the wood, cut the metal some (angles and door openings) and probably add a bit more lumber (bracing material was not included in my kit).
When I built mine I designed it first myself, did a material take off, and decided the kit was less expensive. With the kit the metal was already cut to the proper lengths, I didn't have to worry about the proper length to order, etc. My kit also came with bags of concrete mix for footers, which I hadn't expected. I needed to buy more concrete mix though, as my code required larger footers than what the kit had planned for. I also ordered extra parts that wasn't in the kit, such as base trim, bolts to connect header to the poles, extra skirtboard, and I added different overhead doors.
most of the lumber stores sell pole kits, wickes, 84 lumber, carter lumber, menards. depends on who is in your area. Pole barns are rather easy to design, look at some plans and you can draw your own.
Pole Building Kit Plans :: Pole Building Packages by APM
this site shows you everything you need to know. They have nice kits, I bought from them. I don't work for them, but I should :) .
   / Pole Barn Kit - Northeast Sources #10
This way works also.
Also,
You can also put poles on a normal frost wall w/ footers by using metal post brackets. conventional footers, post frame building.
Side posts are normally 8' oc, but if you put doors on the sides that might change. For 40' long you will have 5 bays, or 6 posts per side. Your end posts can be a little further apart.
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
