Pole Barn: Help Getting Side Pieces In Place
   / Pole Barn: Help Getting Side Pieces In Place #1
kycontrols
Bronze Member
Need your collective wisdom. Started putting the roofing on the barn today. A little of a learning curve but not bad...
Tomorrow will start installing the sides. The longest piece is 22 foot. At a lost on an easy way to get it into positions, what is the trick.
Thanks for sharing your wisdom.
   / Pole Barn: Help Getting Side Pieces In Place #2
Backintheday....the "Top Man" would climb the endwall, throw a leg over the top girt and drop a rope with a c-clamp on it...
Hoist the sheet up....secure to the top girt...repeat as nessesary....
T
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
