Pole Barn Door framing dimensions
   / Pole Barn Door framing dimensions #1
TimboTractor
Eastern NC
LS U5030
Putting up a 40 x 64 x 12' tall pole barn and trying to figure out the doors. I know I want one as tall as I can fit, but not sure of the rough in dimensions for different types of doors. I think a sliding door would give me the most height, but think I prefer the ease of a roll up or roll-back. Also, what are the rough in dimensions for a standard door 3' x 6'8" ?
   / Pole Barn Door framing dimensions #2
On my building my overhead doors are 2 feet shorter than my eave height. 16' eave, 14' doors. I'm planning on doing roll up doors. I agree that sliders will allow for a taller door at the expense of sealing capability, however.
My 3068 walk way doors are prehung. From memory they require 38.5 inch by 81.5 inch rough opening. I have Plyco Series 95EV walk doors. (I just ordered an additional door today as I subdivide my building. Otherwise I would have no idea what model doors I have.)
Hope that helps.
Thanks for that. Wondering if I can get a 11' tall roll up or roll back door on a 12' tall eave height barn.
   / Pole Barn Door framing dimensions #4
You can usually have an overhead door 1 foot shorter than the ceiling without a low clearance package. I have an 11 foot door with 12 foot walls.
   / Pole Barn Door framing dimensions #5
I've got roll-up on two workshops and sliding on two.
The "garage height" roll ups on the right are not bad. The 12' (?)tall roll up on the left can stick and be a bear to get up.
The sliding on the two middle workshops take up a bunch of space but I think they are more reliable.
   / Pole Barn Door framing dimensions #6
For a walk through door, add 2 1/2 inches to the size of the door for the rough in opening.
For the roll up door, you generally make the opening the exact size of the door, but you have to have enough room above the door opening for the size of the door all rolled up. Going off memory, I thought it was 2 feet of clearance above the opening and below the ceiling. I've put in a couple of them and bought them from Muellers. Before framing out my opening, I contacted them and spoke to a sales guy to be 100% sure. I want to know what sizes where available and what my framing needed to be.
Who are you buying the door from?
Eddie
Not sure yet where to get the doors. My local building supply company does not carry the large barn/shop doors.
   / Pole Barn Door framing dimensions #8
I don't think barn doors are an off-the-shelf item, but I could be wrong. The company that just built my pole barn makes all barn doors onsite except for some of the small entry (man) doors. For my barn, I am building them myself. It's a 10x10 opening, with split sliders.
   / Pole Barn Door framing dimensions #9
For prehung doors, the rule I was taught was add 2 inches for a good tight final fit if your rough framing is nice and square. 3'x6'8" would be 38" x 82". Fewer shims required.
The roll up garage doors lose some height due to the rolled up door being so such a large diameter roll. I believe it was 2-2.5 feet height loss on 10-12 foot door. I have 12 ft walls and an 11ft traditional style slide up panel door because I wanted it insulated.
11' height still sounds pretty good for 12' eave. I don't think a sliding door could be any taller because no matter what type of door you use, you still hang it to a 2x12, which takes up a foot of height. So, you can fit a 11' roll back door in a 12' tall pole barn? That may be the ticket.
2025 Swict 78in Bucket Skid Steer Attachment (A42742)
2025 Swict 78in...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A42744)
2007 Ford F-150...
INOP/NON-RUNNING 2009 Mack GU813 Truck, VIN # 1M2AX13C09M004546 (A44391)
INOP/NON-RUNNING...
2018 GENIE GS3246 (A45046)
2018 GENIE GS3246...
Wacker Neuson ST31 (A39160)
Wacker Neuson ST31...
ATOKA TRIAXLE LOWBOY TRAILER (A40519)
ATOKA TRIAXLE...
