Pole barn condensation
   / Pole barn condensation #1
karman 4564
Northwest pa,
johndeere
The contractor starts next week on my new 40x80 pole building,after reading several pole barn build stories i have a concern about condensation,What can or should I do to prevent this from happening,
   / Pole barn condensation #2
Install fans
   / Pole barn condensation #3
Large louvered, screened opening at the peak, on each end - fan on each end. There are web sites that will give fairly specific specs on size of opening and rating for fan(s).
Thank you for the quick reply's,
Does it make a difference if the building is insulated and finished on the inside
   / Pole barn condensation #5
40 x 80 is a great size...
We want pictures!
   / Pole barn condensation #6
Yes. If you have the ceiling well insulated (at the bottom of the rafters) along with good ventilation for the attic space you should be fine. The condensation comes from when you have the inside of the roof a different temp than the outside.
So if you heated the inside and the underside of the roof was getting that heat while cold outside, you'd have a problem. Reverse in the summer.
   / Pole barn condensation #7
Understand condensation and dew point. It will happen- no matter what- it’s science. The thing you want to control is where it’s occurring in the wall.
The fans work because they are bringing the inside and outside temps in alignment or close enough to prevent the condensation.
So if you are doing interior walls and insulation up against the steel siding you could be trapping the moisture in the wall structure (between Sheetrock and metal). Check out something like building science .com. They have the details (drawings) and the studies of ways to prevent moisture/mold issues. We typically just frame the interior walls and hold the batt insulation an inch plus off the steel siding. That HOPEFULLY puts the condensation in an area that can dissipate the moisture.
   / Pole barn condensation #8
If the interior space is to be heated insulation is only part of the equation. You have to keep interior moisture from going through the insulation and condensing on the exterior skin. Vapor barrier is what that is called. It virtually has to be airtight. Like Neumann stated, that is the means of draining that moisture. hat has it own set of problems like corrosion and mold growing. Then again folks tend to get by with things in spite of the science. Usually its pay me now or pay me later (with inflated $). I have seen many steel buildings where the roof insulation is saturated with water and falling down from the weight.
Ron
   / Pole barn condensation #9
Air has a dew point. That is the temperature at which it can no longer hold all the water vapor that it contains. If the air comes in contact with a surface that is colder than the dewpoint of the air then it will condense on that surface, just like on the side of your beer can.
Objects radiate heat from their surfaces. I radiate my heat towards you and you radiate heat towards me and since we are similar in temperature there is no heat loss to each other. The roof of your barn radiates heat towards space. Space has no heat to radiate back towards your barn. This is called radiant over-cooling.
The roof of your barn on a cloudless night will radiate so much heat towards space that it will cool to as much as 10 degrees f below the temperature of the air. This is why frost forms on the roof when the air temperature is still above freezing.
When you insulate the roof, it will become colder because it no longer gains radiant heat from the ground below it. If the insulation allows the air from below to freely come in contact with the underside of the metal roof, then a significant amount of moisture can collect rather quickly, just like on your beer can.
You can limit the amount of water vapor that comes in contact with the cold surface by using a vapor retarder on the underside of the insulation but you must also limit air movement through the assembly.
The concepts are simple. The solutions can be tricky. The conditions, climate and materials all affect the approach that is effective.
I will add just a few interesting things to consider in helping to understand the concept. Notice that the roof of your car(parked out in the open) will be wet with dew but the sides are dry. This is because the sides are facing other heat radiating objects and the roof is facing space. Cloud cover reduces the radiant heat loss from the roof and ground by re-radiating heat back to the ground. The clouds overhead are cold but not "deep space" cold. Dew doesn't fall, it forms on cold surfaces.
One other odd thing to know. Humid air rises. It is less dense and more buoyant than dry air. This explains part of why airplanes have a harder time taking off in high humid conditions. The reason is that air at a given pressure and temperature only contains a set number of molecules and water vapor is made up of oxygen and hydrogen which are lighter than the oxygen and nitrogen that make up air. The more hydrogen molecules are added to the volume of air, the fewer nitrogen molecules are in that volume. Humid air rises until it reaches a level in the atmosphere where it can no longer hold all the water vapor and at that point it condenses out to form clouds. In a still air building, condensation will tend to occur at the peak of the roof first which is why ridge vents are important in a vented roof system.
Roof ventilation is not the only or even the best way to manage moisture but it is one way. There is no cheap and easy way to do a great job of handling moisture in a metal building. There are cheap ways that may be better than nothing. They may work ok or fail miserably depending on your climate and conditions.
Aren't I just mr. Happy?
   / Pole barn condensation #10
On the walls can you use Tyvek between the metal and purl ins? Or should it go between the posts and purlins?
Starting a 42x72 tomorrow. The first 24x42 will be insulated with a mini split. The ceiling will be metal with r30. The bottom of the walls, interior, will be 3/4" plywood 8 foot up with 5' metal on top of that to ceiling. Should I put a vapor barrier between metal ceiling and insulation?
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
20 Ton Hydraulic Bottle Jack (A55787)
20 Ton Hydraulic...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
