Pole barn concrete
   / Pole barn concrete #1
Rodmo1
Hello all,
It is now time for me to do the concrete in my 24' x 28' pole building. I am looking for opinions on my plans and costs. The pour will be 4" thick 3500 psi mix. I have extra goat fencing that was removed for the building which I intend to use for reinforcement. I have a guy that offered to do the finishing for $1000. This includes the roughly 700 sq. foot interior plus whatever is left over from the 10 yards will be poured and finished as an exterior pad in front of the access door. Should not be larger then 60 sq. feet. The guy seems reputable as two friends vouched for him and he works for a large construction firm doing high volume commercial pours. I am responsible for the concrete ordering which looks like it will be $110/yard for a Saturday delivery.
Here are my questions/thoughts:
1. This price seems high as it will only be about 15 man hours max. plus under the table.
2. Guy told me not to bother with putting rigid foam around base of poles where they will contact concrete. Seems to me rigid foam will help prevent cracking from expansion of poles with humidity.
3. Guy told me not to bother with putting lines through pad for stress/crack relief.
Appreciate any thoughts or insight
Thanks,
Rod M.
   / Pole barn concrete #2
Price for the finishing seems high to me also but I guess that is a regional thing. I would never pour that large of area with out relief cuts. It is often said that it is not a matter of if concrete is going to crack it is a matter of when. I would rather control where the cracks are going to be.
MarkV
   / Pole barn concrete #3
Hello all,
Thanks,
Rod M.
1- Get another price to campare, but it seems fair to me if he does all the labor including setup
2- The poles will more than likely shrink but if expansion joint makes you feel better than by all means use it (your the boss/owner)
3- I would cut it if it was mine, I would line the cut up with the posts( takes care of any problem mentioned in #2)
Dont waste your time with the goat fence, fence stretches to much for use as a reinforcment. Rerod is cheap compared to the overall project and concrete isn't something you want to redo
   / Pole barn concrete #4
I would get another bid. Seems high if just doing the final finishing. If doing all the prep work, then it's a lot better.
"Dont waste your time with the goat fence, fence stretches to much for use as a reinforcment. Rerod is cheap compared to the overall project and concrete isn't something you want to redo".
Goat fence is much stouter than regular fence. If it's what I think it is (goats eat tin cans for fun, remember?) than it may be suitable and is better than nothing. Sometimes we use what we have. If it's a matter of throwing the goat fence into a landfill just to buy rebar, i would seriously consider throwing it into my concrete froms (with the proper setoffs to get it into the middle of the pad, of course).
I would use at least one expansion crack and possibly one at every pole if it was me. It may not just be the expansion of the poles but the flexing in the wind that helps get a crack started.
However and whatever you end up doing, keep the thing covered and wet for at least a couple of weeks. 28 days is the official cure time so up to that long will maximize strength. Cover it with plastic and keep it wet with a hose or rain or whatever you have to do for as long as you can.
amp
Thanks for the quick responses. I should have added that I got one other bid last fall before I broke ground and they wanted about $2300 but that included (I believe) steel mesh plus they would have dealt with the concrete supplier. I think I may get an updated quote from them since it seems that they would take care of EVERYTHING (plus they would be insured). Seems like it would be worth it for an extra 1-2 hundred. I will definately put 1/2" foam around base of all poles after reading responses and will also insist on stress cuts.
What is a good slope from back of garage to doors for water drainage?
I am installing 9x7 garage doors...Plans call for exactly 7' from floor to header. I am concerned with the height not being perfect...Does anyone have experience with installing these doors? Is it better to go slightly higher just to play it safe?
Thanks,
Rod M.
   / Pole barn concrete #6
Thanks,
Rod M.
1/8"-1/4"/ft slope for good drainage
The vinyl door stop will take up about an 1/2" if you where to make the door exactly 9' x 7'
But when I frame garage doors I frame it 1" under sized, this allows you to be off by quite a bit and still have the door work good
   / Pole barn concrete #7
I am installing 9x7 garage doors...Plans call for exactly 7' from floor to header. I am concerned with the height not being perfect...Does anyone have experience with installing these doors? Is it better to go slightly higher just to play it safe? Thanks, Rod M.
Overhead doors install behind the opening not in it. If the opening is undersized there's just more overlap at the edges. However if the opening is oversized the wind will blow in around it. Unless you have height restriction I'd go with taller doors even if you have to go to low clearance hardware. Nothing worse than a door that's too short. MikeD74T
   / Pole barn concrete #8
I've poured 5 slabs in the last few years and have only found one good guy to finish them.
Go with the company who does this professionally. There is NOTHING worse than wishing the idiot who finished your floor hadn't made the mistakes you will look at for the next 30 years.
You can use your goat fence, however for a small charge per yard I would recommend also using fibre mesh. This is a material that is mixed with the concrete at the batch plant that acts as rebar; looks like dryer lint. It's cheaper than steel rebar and more even.
Make your slope from your garage door slope the entire length of the interior, or as far back as possible. Good for washing things indoors.
You will get cracks in any slab bigger than 15' x 15'. Stress relief cuts will let you decide where you want these cracks. Your choice if you want them, but you can always fill them with silicone later. If they use a concrete saw to make them then you only have a 1/8" - 1/4" gap.
You didn't mention if the finish is a power troweled finish; this makes a difference to the price but a very nice floor too. I applied an epoxy floor finish to my latest slab - a very nice result on a 1000 square foot floor.
Finally, there is the expression "The bitterness of poor quality outlasts the sweetness of low price." This definitely applies to concrete finishers, so got one that is knowledgeable and is listening to you.
Let us know how you make out.
Cheers,
Jon
   / Pole barn concrete #9
Call your local concrete company and they can provide a list of finishers. After talking to a few of them, I'm sure you will get an idea of a fair price for finishing, and probably could pick a good one just from talking with him on the phone. I also recommend the addition of fiber to the concrete for strength but it does complicate the finishing process. My finisher spent hours picking out the wads of fiber that rose to the top throughout the finishing process.
   / Pole barn concrete #10
Thanks,
Rod M.
Will your stuff fit through a 7' door with out lowering the rollbar?
I got 8' so I don't for get and take out the door or frame like many others have on here.
tom
Kubota BX2230D (A47384)
Kubota BX2230D...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
FRONTIER MG20F LOT NUMBER 83 (A53084)
FRONTIER MG20F LOT...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2006 CHEVROLET EXPRESS CUTAWAY BOX TRUCK (A52577)
2006 CHEVROLET...
