Polaris Sportsmen for farm work
   / Polaris Sportsmen for farm work #1
Lacal
Willcox, AZ
TYM T233HST
I have recently retired from Massachusetts to Arizona and have researched a lot on ATV's and UTV's and am considering the Polaris Sportsmen since I am close to several National Parks, but not sure that the Sportsmen is able to use all the attachments that I think I'm going to need. I'm hoping I could rent some of the attachments like a post hole digger.
   / Polaris Sportsmen for farm work #2
I have a Polaris Sportsman. I use it for pushing snow, pulling a tine harrow, and winching out my 1,200# riding tractor when my wife gets it stuck. I have a 12V sprayer that I use to spray fence lines. The Sportsman's are about the heaviest ATV made. Mine weighs 770#. Weight can be good or bad in an ATV depending one's preferences. I do know my Sportsman is a snow pushing beast with no chains on it. Do they make a post hole digger for an ATV?
   / Polaris Sportsmen for farm work #3
I highly doubt it. If it bound up you'd have a real problem...No 3 point anyway.
So far so good, but not clear on timswi's comment "no three point". Whistlepig makes me confident that the sportsmen could do "almost" everything" I was hoping for it to do. My land is 5 acres of scrub brush and small mesquites along with large crushed stone driveways. I thought about a tractor, but want an ATV for hunting and exploring and hoped to get away with one big expense.
Thanks,
lacal/Larry
   / Polaris Sportsmen for farm work #5
Lacal, the "three point" he refers too is a three point hitch, usually on a tractor, the post hole digger would attach to that, I've never seen one on an ATV.
harvey7 - thanks! I pretty much figured that's what it meant. I just want to be careful I don't look like Mr. Douglas on Green Acres. All new to me, but certainly looking forward to it. I haven't done farm work in forty-five years and sure am glad to be out of the city.
   / Polaris Sportsmen for farm work #7
I have 2006 700 cc Sportsman. I bought it prior to my tractor. I have used it with a small trailer I bought to haul it one and then hook it to 4 wheeler to haul rocks, wood etc. Where I am you gotta be careful not to put too much weight on the trailer and go down a hill. While the Sportsman is pretty heavy and has engine braking a heavy trailer load and down hill can lead to the trailer jack knifing as the Polaris is not heavy enough to 'stick' to the ground. I have had the trailer jack knife the 4 wheeler and the 4 wheeler tires where not turning, trailer was pushing. :confused:
I have used a 12volt sprayer and used a winch to pull logs again some limit by the weight of the 4 wheeler. I eventually got a tractor and it does so much more.
First, thanks for the responses. It sounds like I need one of each now I just need to convince my wife.
   / Polaris Sportsmen for farm work #9
You might want to look into a Tool Cat. They can operate a post hole digger. More money but may be what you realy are looking for.
   / Polaris Sportsmen for farm work #10
Thanks,
lacal/Larry
Sorry about the terminology lacal, But the responses on the 3 point are correct. An atv wont handle a post hole digger, nor should it. Too small for something that has that much torque. If the digger bound up, the atv would end up flipped over:eek:
The Sporstman is a great ATV. My neighbor has a 700 2 up. It rides and drives like a Cadillac and is capable of all kinds of work...Pulling, plowing etc.
Look at a Ranger as well..They have even more utility if you have enough acres to get enough use out of it. They are pretty big, but a really nice machine. I like everything about them except the overall size...Too big for me.
The Tool Cat is a killer machine but 30 large is a bit much.
378809 (A51573)
378809 (A51573)
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
