Polaris Big Boss 4x6 250 1990 idile problem
   / Polaris Big Boss 4x6 250 1990 idile problem #1
Bob53
SW/PA
B3030
The ATV will not idle in reverse gear and just stalls out when you put gear in reverse. Always works in Low and High, stalls in reverse only 50% of the time. One day reverse works well next day will not work at all? Being warm or cold does not seem to matter. Any ideas on what to look at?
   / Polaris Big Boss 4x6 250 1990 idile problem #2
i had a 125 honda fourtax that would do something like that .it was the reverse gear inside the crank case that had a broken tooth. it would work sometimes and sometimes it would kill the engine because the broken tooth would get lodged in the gears.get a shop manual before disasembling it it will come in handy because them gears stack up in there and got springs too and if you go tearin into it without noticeing a missing part or even a part might be broken and you can't tell until you look at the manual to see what it looked like new.
   / Polaris Big Boss 4x6 250 1990 idile problem #3
Is the fuel filter clean?
interesting on the tooth, yeah i better get shop manual.
yes i changed the plug,air,fuel filter.
going to change gear oil since cannot remember last time and maybe look deeper into gear case.
thanks
   / Polaris Big Boss 4x6 250 1990 idile problem #5
the gears inside are very close together so even if a tooth is chipped just a little bit it can still lock up an engine .maybe take off the cover and just turn the gears slowly and check them . the peice that was lockin up my engine was the size of a diamond chip not even a carrot maybe like a 1/4 carrot in size. check that gear oil for fragments too.
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52748)
NEW 2022 Load...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Cat 953C Crawler Loader (RIDE AND DRIVE) (A50774)
Cat 953C Crawler...
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
