Poison Ivy
   / Poison Ivy #1
RobS
Super Member
Goshen, IN
None!
I'm surprised there isn't more discussion here on poison ivy. I recall a thread last year on eradication but that won't help my itching /w3tcompact/icons/shocked.gif Having been recently inflicted I've done some research. Here is a very thorough and well done site covering the topic...
Poison Ivy
I found a recommendation for this stuff, Zanfel. My wife and I are trying it. Jury is still out and it is VERY expensive (we paid $32 for a small tube) though we figure if it works we'll pay about anything. Next step is to teach ourselves and the kids what the stuff looks like. Around here it's not yet leafed out though.
Any other suggestions more than welcome /w3tcompact/icons/smile.gif
   / Poison Ivy #2
Hi Rob,
Grew up around poison-ivy, moved West, and had to re-train for poison-oak.
That "next-step" of recognition/avoidance training is THE one!
Enough close-attention observation (of all seasonal-variations in appearance), and enough scratching, and everyone will develop almost a "That's poison-ivy!" sixth-sense awareness of what is-or-isn't IT!
Hope that spendy stuff works, ... but you're right; tormented people will pay ANYTHING! /w3tcompact/icons/blush.gif
Good luck!
Larry
   / Poison Ivy #3
Rob, I hadn't heard of the Zanfel before. Be sure to let us know how well it works. When I was a kid, I think the standard cure was Calamine Lotion; messy pink stuff. The first, and worst, case I ever got was when I tore the poison ivy off some trees with my bare hands (I'd always been immune), then rubbed my eyes when I got something (bark or dust) in them. That time required a trip to the doctor for an injection. As an adult, for a number of years, I used Ivy-Dry, a very thin, clear liquid that seems to work pretty well, but the last couple of times I've used "Eckerd Maximum Strength allergy relief GEL" (2% Diphenhydramine Hydrochloride); same as Benadryl lotion or gel I think. It's a little thicker, but also clear liquid and I think I like it a little better than the Ivy-Dry.
And I know how to recognize the stuff; that just doesn't prevent me from having to get into it once in awhile./w3tcompact/icons/frown.gif
Bird
   / Poison Ivy #4
I'm really allergic to poison oak. I get a oozing blistery rash /w3tcompact/icons/frown.gif
I have found Avon and Technu products work well, and thier less expensive than what you mention.
Both Technu and Avon make a cleaner, but by then you most likely have caught at least a bit of it. These cleaners work pretty good. Both companies also make a pre-exposure condidioner, which works to "block" the poison ivy/oak oils from getting on your skin. But, they typically are only good for an hour before they dry or rub away.
The best thing to relieve poison oak is pure aloe. My wife grows some; it works great. Otherwise, the over the shelf Aloe gels work good.
Another thing that works exceptionally is old fashion homemade lye soap. My Grandma used to make it from rendered lard. I have never seen anything that works nearly as well.
I get Technu at the local pharmacy. We get Avon on-line. I'll have to look at thome for the actual name of the Avon stuff.
RobertN in Shingle Springs Calif
   / Poison Ivy #5
I used to deal with poison ivy when I was little (in Illinois). Got a case of it every year until one year my brother & I must have rolled in it or something. We both got supreme cases of the stuff. We were both miserable for a couple of weeks. Never got it again, and assumed I became imune.
Many years later in California, I was out for a motorcycle ride, and had a minor misshap. The bike went down an embankment through a bunch of poison oak. My (future) wife was along, and warned me not to go through the PO, but I was ticked off, and hollered "I don't get that stuff!" Famous last words. I didn't get a bad case, but it was a surprise.
I have since found that given the right circumstances, I will still get it. It never seems to get very bad, and if I ignore it, it will go away in a day or two.
When I know I have to work around it, I will put on a barrier cream (I've tried several, and can't tell the diff. /w3tcompact/icons/crazy.gif) After, I'll clean up with Tecnu. It really works. As long as I do the 1-2 punch barrier + cleanup with Tecnu I won't get anything.
By the way, you should note that it is very bad to clean up with hot (or even warm) water. This will open up your pores, and get the orushiol into your skin.
Now, just to make you all think that I'm totally crazy /w3tcompact/icons/crazy.gif, I'll let you know that my wife is seriously into California native plants. Well, Poison Oak is a California native. In fact, my wife believes that it is an important native for many birds and insects that are good for the environment. So, she goes around propogating the stuff everywhere there is a potential for erosion. Turns out the stuff is excellent for erosion control too. Go figure. BTW- She gets it a lot worse than I do, but she deals with it with a smile. Call us a couple of kooks./w3tcompact/icons/smile.gif
The GlueGuy
   / Poison Ivy #6
Tecnu is great stuff! I personally dont get it too bad but when I do this stuff stops it. A relative used to use carb cleaner to dry out the poison. Tom
   / Poison Ivy #7
Rob, If you can, get a couple goats on the property...They love the stuff. in short order you'll not have a poison ivy problem.
Rick
   / Poison Ivy #8
Rob, Thanks for the excellent info. I seem to to get the stuff just by being within a mile of the it. I have a perscription for Methylprednisolone tablets. It is a steroid I believe. You need to take it over a 6 day period, starting with 6 pills and progressing down to 1. It is the only thing that works for me when I get the itch!!!!!
   / Poison Ivy #9
My wife also uses just plain alcohol when we are low/out of Tecnu. That seems to do the trick pretty well too, if not better. The idea is to have something that will "cut" the oil and allow you to wash it off.
The GlueGuy
   / Poison Ivy #10
Yeah Glueguy,
I have found that if I realize I've 'gotten into' poison ivy, if I am able to get to a shower withing 3 or 4 hours of contact, and wash REAL well, (like double and triple scrubbing) I can prevent any outbreak. I get it pretty bad if I don't keep after it. A few years ago we had a whole wall of the hog pen covered with the stuff. I pulled it off and dumped it in the woods and went right to the shower. No problems.
Steve
"Amateurs built the Ark. . . . . . . .Professionals built the Titanic"
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A53473)
2023 NEW HOLLAND...
Kawasaki NR (A50324)
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2007 JOHN DEERE 7630 TRACTOR (A53843)
2007 JOHN DEERE...
