pneumatic seat pump dead - mahindra 8560
   / pneumatic seat pump dead - mahindra 8560 #1
dal929
I hit the button to add some air in the pneumatic seat and no sound from the pump. I can't seem to find anything on the seat/pump online, anyone have any info on troubleshooting this system?
thanks
Dal
   / pneumatic seat pump dead - mahindra 8560 #2
I was not aware the 8560 had a pneumatic seat.
hugs, Brandi
   / pneumatic seat pump dead - mahindra 8560 #3
Nothing exotic. Check your fuses, check the wires leading to the switch, check the switch connections and switch function.
A generic cause of this problem would be wiring damage in the area of the seat suspension scissors mechanism and an associated blown fuse.
Use a test light or VOM to troubleshoot circuits.
   / pneumatic seat pump dead - mahindra 8560 #4
If the compressor is bad there are lots of 12VDC compressors out there for not a lot of money. You don't need much pressure or volume for just a seat so you don't need to buy anything fancy. You could likely even find something in a junk yard. Lots of cars had small air compressors for this or that mostly suspension.
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
