tessiers
Platinum Member
- Joined
- Sep 22, 2007
- Messages
- 727
- Location
- Central Maine
- Tractor
- 05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
For any of you that have built grapples and or snowplows on their loaders, what did you plumb the lines with? I plan to plug into my power beyond and run 2 lines to under the deck where the loader quick connects are and install another set, then up the loader frame to the valve, I have a 2 section I want to install, 1 double acting for the angle on my snow plow or grapple, the other is a single acting valve with float to run the cutter heads on my Mower or Chopper. Then I need to run down the loader arm with 2 lines and another set of quick connects to switch implements. The rub is that I am no prima-donna however I don't like the idea of rubber hoses running down the loader arms.
3/8" Brake lines?
1/4" Black Iron?
What have you all used? from the factory all the lines are steel, they look like brake lines to me.
3/8" Brake lines?
1/4" Black Iron?
