Plumbing Hydraulics on a YM 1300D
   / Plumbing Hydraulics on a YM 1300D #1
Hondo1
Western NY
YM1300D
I just picked up a great dozer blade for my YM 1300D (thanks Gary J.) I have a manual and almost everything seems to fit as the dozer blade is for a 155D and the YM 1300D is almost a duplicate match, ALMOST. I can't seem to find where I attach the main hydraulic lines. For the 155D it shows a diverter block but the manual does not show where it is and it is not where Gary showed me. So question is, how do I plumb the main hydraulic lines to the control valve?? I sure hope someone can help here as I am by no means a hydraulics or plumbing expert. I can do the work if someone shows me how.
Thanks in advance for any help given.
Mike /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Plumbing Hydraulics on a YM 1300D #2
Mike,
I would assume the 1300D to be the same as the bigger brothers. Use an open center valve. Cut the high pressure line, and use braze on or compression fittings. Run the pressure line to the valve "in" port. From the valve "out" port run back to the line you cut that goes to the main hydraulics.
I think....... /forums/images/graemlins/confused.gif
   / Plumbing Hydraulics on a YM 1300D #3
The simplest way to add hydraulics is to cut the pressure line (small line from the hydraulic pump). Braze on fittings or compression fittings can be used to fasten the hoses to. Run the pump line to the IN on the valve. Run the OUT to the line to the 3 point on a 2 hose system. On a 3 hose Power Beyond valve run OUT to the transmission housing & the PBY to the line to the 3 point. The best system is to use the PBY system.
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A51572)
2021 Big Tex...
8ft Perforated Metal (A51573)
8ft Perforated...
Killbros 260 Seed Conveyor (A53472)
Killbros 260 Seed...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
