Plumbing for hydraulics
   / Plumbing for hydraulics #1
norgeman
Wisconsin
john deere 3320
I have a bobcat 500 that I can no longer get a part for that connects to the pump. It is a straight pipe that has a y joint out of it and I was wondering if galvanized pipe or some other pipe would work. Thank You.
   / Plumbing for hydraulics #2
Don't use plumbing pipe. Its only rated for 300PSI (if that), not the 3000PSI (or more) that your bobcat runs at.
You want high pressure rated pipe or hose and a Y fitting.
Aaron Z
Thank You Aaron, I appreciate the info.
1991 HEIL FUEL TRANSPORT TRAILER (A52472)
1991 HEIL FUEL...
2020 PETERBILT 567 TRIAXLE (INOPERABLE) (A52472)
2020 PETERBILT 567...
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
