plumbing a grapple off the backhoe ls3033
   / plumbing a grapple off the backhoe ls3033 #1
timbo350
okeechobee
ls 3033 tlb
I have a 2013 ls3033 with the loader and backhoe package from the factory I would like to build a grapple bucket for the front ive looked at the third function kits that are around 800.00-1000.00.I was wondering if I could plumb into my hydraulic lines running to my backhoe with a open center style lever mounted next to my loader valve I have some hydraulic knowledge ive built hydraulic steering systems for swamp buggies any info or help would be much appreciated
   / plumbing a grapple off the backhoe ls3033 #2
You should be able to buy an additional rear remote kit from your dealer. Would give you factory hydraulics to run a cylinder for the grapple and additional lines could be bought at any local hydraulic shop. Would be far less than the $800-1000 range. We keep rear remote kits in stock.
Ok how much are the kits if not what valve should I use
   / plumbing a grapple off the backhoe ls3033 #4
Just did mine last week. I added 1 rear remote for $250. from dealer. Not hard to install. (Got remote for cement mixer.) I ran lines up to front for $148 to include fittings. Works great on my grapple. LS remote lever is next to right side of seat. 168" lines work great. use 90 degree fittings on back to reduce the line bend.
If adding remotes, just as well buy the kit to add 2 $400.00. I wish I did. bought a stump grinder that needs 2. Will cost me more to add second remote now.
ROME AH-240 LOT NUMBER 130 (A53084)
ROME AH-240 LOT...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
