Plugged snow thrower
   / Plugged snow thrower #1
fatboy999
LX178
I have a LX178 rider with a 38 inch, single stage snow thrower. When the snow is wet it plugs the shoot. Does anyone have a solution for this problem?
   / Plugged snow thrower #2
Welcome to TBN. :)
Try taken less also slower traveling speed.
I've read that some spray chute area w/WD40,Pam food spray,silcon base.
   / Plugged snow thrower #3
A good coat of wax or a silicon lubricant helps and moving forward slowly at maximum rpms helps but wet snow packs easily and starts to clump before it reaches the chute.
   / Plugged snow thrower #4
Keeping the rpm up and slow speed ahead is about the best one can do.
It is the nature of the beast with wet snow. The snowblowers plug up too.
Just be sure it is off when unplugging...friend lost part of his hand unplugging his while running... :mur:
   / Plugged snow thrower #6
And for safety sake, KEEP YOUR HANDS OUT OF THE SHOOT! Stop the engine and at the end of the day rest with 10 fingers and a cup of hot coco with something extra.:thumbsup:
   / Plugged snow thrower #7
The key word is ,I have a single stage snow thrower. They are the worst design as far as snow blowers go. Really no good for anything over 3" to 5" lite snow. Sorry to say but if your in an area of high snow falls, but a duel stage blower.
DevilDog
   / Plugged snow thrower #8
devildog1
Haven't found that true at all, but that may just be for most of our WI snows.
   / Plugged snow thrower #9
I had a 36" single stage on my Simplicity that actually worked pretty well. I used Pam on the chute and didn't have any clogging issues. I ran the machine at max rpm. I found the key not clogging was using the correct ground speed. If I went to slow it would clog, to fast the machine would bog down, then clog. Get the ground speed right and a single stage will throw just about anything. I had no problem moving 12" or more at a time. At least that was my experience.
With the wet snow I get here along the CT shoreline, I had the best luck going as fast as possible without overloading the machine. Keeping the auger fairly full and thereby keeping the snow really flowing out the chute worked best for me.
   / Plugged snow thrower #10
I agree on the land speed and keeping the auger full I found that out last year being my first year with the single stage. This year I have an even better solution I acquired another free cub cadet and then scored a free plow to boot !
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
