Plug tractor tire.
   / Plug tractor tire. #1
Oldtrout
Nova Scotia
Kioti CK25
Last week I picked up a nail in my rear tire:mad:being a half mile from home and not wanting to pull off wheel in customers yard,I plugged tire and completed the day. When I got tractor home I checked air pressure had 20 lbs,checked yesterday still had 20 lbs., 4 days later. I was wondering if anyone had long term sucess with tire plugs,or should I pull wheel and have patched on the inside?
The tires arn't filled with anything other than air and are Ind 15-19.5 on my kioti ck25. Since I probably will probably pick up another nail,with my luck :eek: I thought I would wait till I had a few more holes and than get them all patched at once.:)
Any thoughts anyone??
   / Plug tractor tire. #2
You can leave the plug in for the life of the tire. I've had plugs in for years. No need to patch from the inside unless the plug is leaking. Even in that case I'd probably just replug it.
Sincerely, Dirt
   / Plug tractor tire. #3
I wouldnt worry about pulling it off if it is holding air. Just carry a couple extra plugs around in case it happens again. I have 3 plugs in my neighbors tractor and they are all seperate holes and still holds air just the same.
   / Plug tractor tire. #4
I plug all my tires when I pick up a nail, etc. That goes for the atv, truck, cars, trailers, and tractor. Dirt's right...a good quality plug will last the life of the tire. I keep a plug kit in all my vehicles. A good plug kit will pay for itself with a couple flats. A lot cheaper and less hassle than having to patch the tire from the inside. Sometimes with a large hole I have plugged the hole using two plugs.
   / Plug tractor tire. #6
Service stations now have available some sort of 'high-tech' plug that can plug some pretty big holes. One time a guy put about 4 in a fairly good sized hole and it held forever.
Once in a pinch I flattened a nail and drilled a small hole in flat area and inserted some poly cord dunked in contact cement inserted and lit the contact cement.
That plug lasted forever! (I now always have a plug kit 'on hand')
   / Plug tractor tire. #7
My tires get plugs, I get far, far too many flats to do otherwise.
I do not change them out, or do anything else with them, unless they are leaking or giving me problems, which is seldom.
   / Plug tractor tire. #9
Echo to all that has been said above. When folks talk about a "good" tire plugger you should be aware that there are some low cost and poorly made sets out there. Spend the money on a good one (you can usually tell by how sturdy the handle is) and you won't regret it.
Anyone ever plug a hole in the sidewall?
   / Plug tractor tire. #10
I have never done a sidewall. I would be careful about doing a sidewall, especially if any cords are cut. I would say to take the tire into a tire place if it's in the sidewall and let them handle it.
As to plug kits...I have the auto repair kits from Safety Seal. The difference between truck plugs and car plugs are length of the plug.
Tire Repair Kits
John Deere MX15 (A44501)
John Deere MX15...
2006 Ford Crown Victoria Sedan (A42744)
2006 Ford Crown...
2022 FORD F-350 (A45046)
2022 FORD F-350...
2006 Isuzu NPR Flatbed Truck (A42742)
2006 Isuzu NPR...
DIAMOND PRODUCTS CORE BORE (A45333)
DIAMOND PRODUCTS...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A44789)
John Deere 6105E...
