MedTex
I have learned so much researching this forum (thank you!) and am almost ready to pull the trigger on a new package deal. Am I on the right track? Also, I'm still undecided about tires (R4 or R1) and the 4n1 bucket.
Proposed Package:
John Deere 4320 Tractor 4WD, Power Reverser, 400X loader, 3rd rear SVC, Water in rear tires
WR Long 4-in-1 Loader UJ2-72 with Flat Tooth Bars (better than the Frontier 4n1?)
John Deere MX6 Cutter, John Deere I Match, Post Hole Digger 9" Auger, Canopy Top
Primary Uses/Projects:
Cutting 3+ acre field and tall grasses along creek (No pristine lawn)
Cleaning out creek bed that fills up with gravel & a little silt after floods
Road grading (Material is caliche and limestone gravel. Road is very steep in places.
Minimal farming of a 5 acre food plot (This is not heavy clay soil)
Occasionally grappling a big rock, juniper brush piles, logs, etc.
Questions:
R4 or R1 tires? We don't have much thick mud. Not worried about tire marks on pristine lawn (don't have one). No heavy farming needs. The creek bed (where I will be loading gravel) is full of gravel/rock coated with thin silt. Bottom of creek bed is hard pan/solid. I need to be able safely drive and grade a steep ranch road. There's no mud on it -- only gravel -- 2WD vehicles spin in the gravel on the steepest parts. My trailer bed is 6'10" wide.
Will the 4N1 be able to adequately do the road grading? This is mainly spot work to fill/smooth ruts and wash-outs caused by water run-off. I hope to save money by not buying a boxblade and put that money into the 4n1.
What is the best setup for the 4n1? I don't really want to spend the money for an electric over hydraulic setup. I will be getting a 3rd rear remote regardless. I would like to be able to close the jaws and curl the bucket at the same time, but this is not mandatory.
Many thanks!
Proposed Package:
Questions:
Many thanks!
