Snow plowing snow w/FEL?
   / plowing snow w/FEL? #1
twodogs
Pittsburgh, PA
Kubota B7800
Hey Folks-
I am in the Pittsburgh area & have a B7800 with a FEL. I tried plowing the snow with the FEL & have had pretty decent results. Is there any reason that I shouldn't do this? My primary concern was damaging my paved driveway, but I want to make sure that I am not doing anything that would cause a problem with my tractor. I have been leveling the bucket, dropping it to the float position, and then angling it a bit to scrape the snow. So far, it has worked well. I would appreciate your thoughts.
   / plowing snow w/FEL? #2
I have the same tractor and plow with the FEL, I thought about going with a plow, but I wouldn't be able to pile the snow up as high if I did. I love to plow snow at night too, I put my Ipod on and light up the tractor and off I go. My next addition to my tractor will hopefully be green LED lights.
   / plowing snow w/FEL? #3
I do the same with my 7800 except I have a gravel drive. I wouldn't use the FEL if I had a paved drive. Even in float if you catch the driveway with the corner of the bucket you could cause some damage to the driveway. Depending on the amount of snow you get, I would either get a rear blade or a blower. Even with the rear blade, I would get some type of softer edge on it such as an old conveyor belt or horse mat.
   / plowing snow w/FEL? #4
</font><font color="blue" class="small">( My primary concern was damaging my paved driveway, but I want to make sure that I am not doing anything that would cause a problem with my tractor. I have been leveling the bucket, dropping it to the float position, and then angling it a bit to scrape the snow. So far, it has worked well. I would appreciate your thoughts.)</font>
I don't see how you can cause any sort of problem with your machine. The only problem I see is the inability for snow to roll off the bucket, as it does on an angled plow. I still use my ATV/plow to do my driveways - it is WAY faster than the tractor would be. As for driveway damage - dragging the FEL bucket on the asphalt in float is no different than dragging a plow blade. Besides, it's cold and asphalt is really hard this time of year /forums/images/graemlins/wink.gif.
Jay
   / plowing snow w/FEL? #5
It should work fine and you won't do any damage to the tractor. I did manage to put a few gouges in the driveway when I was backdragging away from the garage. After I backdragged one area and then moved to the spot right beside to backdrag again. The tractor tipped slightly when the rear wheels went up over the snow that I had already backdragged. This caused the loader to tilt and the corner of the loader to gouge the driveway some. This only happened when we had more than a foot of snow and the backdragged pile was several feet tall. If the pile was around a foot tall the tractor didn't tilt enough to cause a problem.
I am buying a snowblower this year though. Not because of a problem with the FEL but I don't have a really good spot to pile the snow and about February every year I need to move the pile. I want to throw the snow once and not worry about it again.
Good Luck,
Kevin
   / plowing snow w/FEL? #6
What are the thoughts on wearing out the bottom and leading edge of the bucket? I know others have put skid plates on the side of the bucket, or put a plastic edge on the front of the blade, but how much will your bucket wear down over the years if you don't?
   / plowing snow w/FEL? #7
That's been a question I've wondered about, as I plow my paved driveway with my FEL. I figure when it gets worn out it will be no big deal to weld another plate on the bottom and start over again.
Using float & angle of the bucket it's pretty easy to control the amount of scraping that goes on.
   / plowing snow w/FEL? #8
"Even in float if you catch the driveway with the corner of the bucket you could cause some damage to the driveway"
Just curl the bucket slightly back...so the cutting edge doesn't touch the drive. The aft end of the bottom of the bucket can be on the surface. As long as the cutting (leading) edge of the bucket isn't on the asphalt, you shouldn't do any damage.
Personally, I use a rear blade...works much better (IMHO) then the bucket.
   / plowing snow w/FEL? #9
I used my 72" loader bucket to plow about 9" of wet snow (not the light fluffy stuff) last night (not 1st time plowing snow with loader). I've got a 300 foot uneven, gravel and dirt driveway about 10' wide. Down near the house it opens up to about 25' square. The only reason I used the loader to do the whole driveway is because my 05 Ford F-250 plow truck was in the shop. If youv'e got a flat, paved, wide driveway I think it would be a whole lot easier. With long, narrow, uneven driveways, it's a really inefficient way to move snow. With a snow plow, it takes minutes. With a loader it takes much, much, more time. Every 6 feet, the bucket is full and have to do a bunch of forward and reversing to hold the bucket over the side of the driveway edge to dump the snow. If you like seat time, then it's great. When I started last night with the loader, I felt like I'd be doing the driveway all night. Once I started making progress, I started to relax and just enjoy the seat time. If it was still sleeting, raining or heavy wet snow, It wouldn't have been any fun for me. I did spend guite a bit of that time thinking about how I'd mount the old 7 1/2' Meyers snow plow to the tractor.
Howard
   / plowing snow w/FEL? #10
Hi Roy - I was thinking about the rear blade option on my tractor - I had a question on plowing snow you've already driven over. Do you find the rear blade will pull it up, or do you just get that slippery compacted mess that I leave behind now? My FEL does a good job, but as previously stated it takes a lot more back & forth trips to get the snow that I know a plow blade would get in one pass. The problem is once I drive on the snow it's too compacted to get off the driveway, and my gosh is it slippery when it's frozen.
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
1985 International X Con Semi (A50514)
1985 International...
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A51242)
2013 CATERPILLAR...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2008 SATURN VUE (A50324)
2008 SATURN VUE...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
