Plowing Problems
   / Plowing Problems #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
OK you garden plowing TBN'er......What do you think? I have used this plow (Leinbach #19), 12" single moldboard for nine years on this 50 x 100 garden.
It does not get easier even with more study and adjustments. I've replayed several of the EA videos over the years and tried to take more time to make adjustments as I go...such as adjusting the pitch and the level of the shear. Today the top couple inches of soil are dry, but the lower is heavy with moisture but not really wet. Using the Kubota B2620,.....it has no position control nor draft control, I try to adjust the plow (raise) when the engine just about stalls....which usually leaves a couple feet of unplowed ground.....which effects the next pass.
Cheers, Mike
I
   / Plowing Problems #2
Well - a couple things. It looks like you have done a pretty good job. I don't think you need to plow quite so deep. I'd go over it one more time with your drag.
I have a single bottom moldboard plow - Pittsburg. I have draft control - hydraulic top link - position control. I have NEVER done better than what you have done there.
It didn't take me long to learn that there is a whole lot more than just dragging the plow behind you.
   / Plowing Problems #3
How are you raising the plow if it has no position control? :confused3:
Do you know how to use draft control? I see a pin that doesn't look like it's doing anything. Do you have your 3-point set up for draft control? Many, as I do, set their linkage to the LEAST sensitive draft control when doing anything but plowing--Mowing, tilling, raking, grading, etc. It's easy to forget to put it back for plowing.
   / Plowing Problems #4
I looked at your pictures and it looks pretty good, leaving me to wonder "What was your question?"
It looks like you have some pretty good soil there. Where are the rocks? (I can't make 2 passes without tripping my plow.)
   / Plowing Problems #5
For the plow you have,that's about as good as it get's. I suggest you trade that plow for a tiller,one way drag plow,drag moldboard or 2 disk 3 point turning plow (in that order of quility of job they do). I've seen many full time farmers struggle with setting 3 point moldboard plows and their plows were far better than yours.
First off,that plow is poorly designed and will never do exceptable in heavy soil. The plow lacks a trail wheel and means of adjustment for angle. If you must stay with 3 point,beg,borrow or steal a disk type turning plow. It require's less power,simple to set and does far nicer job in heavy soil. If you have turning room,look for a drag type from the time most tractors didn't have 3 point. There's no demand so they are cheap and tough as nails. Your soil look's like it would benifit from a generous amount of organic matter. Plant cover crop in off season and start composting.
   / Plowing Problems
Tinhack... When the engine begins too stall, I just bump up the 3 point to continue. Since the B2620 has no draft control or position control...I have no experience there
I've never used that lower pin. Maybe it has some function for depth of some attachments???
Jstpssng This garden has been worked for 45 years....the first 35 with a walk behind Sears front tine tiller. Life was a lot simpler then and I was a lot younger. No rocks
here. I've read on TBN that some just use their tiller and some do "no till" gardening. I'm ready for something that is easier on me and the tractor.
jaxs....... Being a tractor newbie in 2009, I bought the plow for a BX subcompact.... and since have upgraded to the B models and have a nice tiller. I was thinking of
unloading the fall collection of leaves (Cyclone Rake) into that rough plowed plot so they fall into the furrows and spaces to be tilled in the spring, but don't have
a drag...yet
oosik..... Thanks for the compliment...I tried to adjust the top link to bring the shear tip up....but it didn't seem to help. More Horse Power might have made a difference.
   / Plowing Problems #7
Oldballs
Due to the fact your tractor has no draft control have you considered installing an adjustable gauge wheel to help control plowing depth. Your photo may be deceiving but moldboard plows I've utilized were designed for top frame to be level when plow bottom is in the soil.
   / Plowing Problems #8
Wow! I guess I didn't realize they made farm machinery without position or draft control. What's the use in having a 3-point system?
I would call that "tractor" a lawnmower but how would you even mow with an implement? You need to be able to set a relatively consistent height. Perhaps an adjustable chain to limit drop? I don't know but that sounds dangerous if used with a plow. That could flip you backwards in an instant. I can't believe Kubota would produce such a machine. :eek:
   / Plowing Problems
TxJim......Thanks......A gauge wheel would help a lot as the best solution. Hum-m-m... Remind me not to post plowing problems until I install a gauge wheel. :)
Cheers,
Mike
   / Plowing Problems #10
When setting up the plow make sure the land slide is in line with the direction of travel and level when at furrow depth.
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2000 John Deere 770CH Articulated Motor Grader (A49461)
2000 John Deere...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
FUEL TANK/TOOL BOX COMBO (A50854)
FUEL TANK/TOOL BOX...
