Plowing Pipe
   / Plowing Pipe #1
deere36
Bronze Member
North Mississippi
John Deere 3046R
I have been intending to build a plow to plow in water pipe, wire, etc. and have borrowed one from a gentleman in a nearby town but his was very crude. Then one day I saw this idea on Kenny D's photo album and it is very simple to build using a 2 inch receiver tube and a scarifier from a box blade.
Added two pictures of plow not in ground, as you can tell I used some scrap steel for a gusset and had to fill in with welder.
I cut a 1 inch piece of 4 inch steel pipe and bend the PVC through the steel pipe and tape the PVC back to itself and hook the steel pipe over the point of the plow so the PVC stays on the bottom of the plow point, it is important to make several passes to loosen ground before burying pipe so plow goes as deep as possible.
Thanks to Kenny D and all of you guys for good ideas and suggestions
Larry
   / Plowing Pipe #2
How about a pic of the business end of this tool? Only show pics with it buried.
thanks
   / Plowing Pipe #3
Glad I could help D36:thumbsup:
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A53424)
Year: 2017 Make...
2017 Nissan Versa SV (A53424)
2017 Nissan Versa...
2009 Kenworth T800 Tri-Axle Day Cab Wet Kit Truck Tractor (A52377)
2009 Kenworth T800...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
