Plowing choices, NEED advice ! one bottom
   / Plowing choices, NEED advice ! one bottom #1
Trap
Northeast KS
Kubota B7610,
I have a Kubota B7610 25HP tractor 4WD. Looking for a plow for garden plots. Looked at Leinbach model 19-12 made for smaller tractors, also saw the model 81 which looks larger and stronger. I also saw a JD 14" but my control arms would have to open to 27" whereas my other 3pt stuff has the pins turned in and closer to 22". Any one use a setup like this on similar tractor? (cost are all very similar so not really an issue-$50.00 diff). I like the looks of the JD (locale dealer) and price is OK but the spread on the arms has me concerned. I'm not sure my arms will open far enough or if pins can turn in instead of out. It may not be the right fit for my rig. Any ideas will be welcomed.thanks..........
   / Plowing choices, NEED advice ! one bottom #2
Go for it. Buy it with the understanding it needs to fit, or be re-fitted to work. :)
Pics of it working would be great.
   / Plowing choices, NEED advice ! one bottom #3
27" is the common width for a CAT-1 3-point, so the rest of your stuff is sort of, well, odd.
I'm thinking you would have better control overall if you put all of your pins out.
Just me thinking out loud...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2013 Chevy Silverado 2500 HD (A51039)
2013 Chevy...
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
