Plow with BoxBlade??
   / Plow with BoxBlade?? #1
lakngulf
Veteran Member
Lake Martin Alabama
Kioti CK30
For most of my projects I am in the use what you got mode of operation. This spring/early summer I plan to prepare some new spots for fall food plots. Also, want to plant some chufa for the turkeys but it is getting late for that.
The soil that I want to break is fairly rich with a sandy loam base, for the most part. It has been pasture for many years. During the winter I cut it as low as I could, and now want to break it up before the grass starts growing again. I have a disc that can be used when the soil is loose and/or moist, but need something to work as a breaking plow.
What are the pros and cons on using box blade diggers as a subsoiler? Has anyone given this a try?
   / Plow with BoxBlade?? #2
i never tried it, but if all you want to do is loosen the soil for the disc, then it might work. i'd lower the rippers to the max and then just engage them into the soil w/o the cutting edge.
   / Plow with BoxBlade?? #3
I know it’s been done, though I have no experience. If your disk is adjustable, you could skip the “plow” step if you really wanted to. In the past I’ve sprayed with gly, then once everything was dead I scalped with the brush hog and started disking. It took a few passes and didn’t get all that deep, but it worked.
   / Plow with BoxBlade?? #4
How deep will the rippers on your box blade go. Most only adjust 2 - 3 inches I think. Shortening your top link might get a hair more.
Biggest concern would be these will act like a rake and fill up with any lengthy debris.
Won't know unless you try.
Disk may / will also work depending on the cut angle and weight of the disc. Either way expect to do more than one pass.
Roy
   / Plow with BoxBlade?? #5
I built a reciever style hitch to go on my tractor 15 yrs ago. Built it really heavy duty. Years later I needed the same thing you speak of. I took a piece of solid 2 X 2 stock about 3' long and slid it into the reciever hitch. I then took a piece of 3/8" thick wall 4X4 tubing and built exactly what was inside my box blade to hold the teeth. It's basically a "T" with the teeth spaced about 10" apart. Works great. I use it as a sub soiler and also to rip out small stumps and roots.
After losing a tooth several times I no longer use the pin and clip system that was in the box blade. I used 1/2 in #5 hard bolts with nylon lock nuts. Haven't lost one since. Something about the hairpins as they kept coming out. But my teeth are loose and floppy, like in the box blade.
Also, over time I noticed the slots I cut for the teeth to fit through the 4 in tubing were taking a beating. I cut pieces of 1/2" X 1" flat bar about 3 inches long and welded them on the top in front of the tooth and on the bottom behind the tooth. The pressure points when teeth are engaged.
To mount the 4" tubing onto the 2" solid stock, I cut 2 square holes in the 4" and slid the solid stock all the way through. I then welded it up front and back. I feel that is much stronger than butting it and using gussetts. That part has not taken a beating, holding up good. I had it on a 90 HP tractor and bent the solid 2X2 stock pulling at a stump larger than it would handle. I found the right tree in the woods to bend it back straight, still hanging in there.
Right now my FIL has it. He is really bragging on what my old home made rig can do.
Hope this helps. Any questions, feel free to email me or ask right here.
   / Plow with BoxBlade?? #6
I actually did this yesterday, I dropped the scrappers, retracted my hydraulic top link all the way and broke some very hard ground before running a tiller on it; could just as easily used a disk, but I wanted a really fine seed bed; worked really well.
I have a plow at another farm, but it was one of those spur of the moment things and I didn't want to take the time to go get it for a fairly small area.
   / Plow with BoxBlade?? #7
if you lower them to lowest, and tip it as far forward as possible, i bet you can get quite a few more than 3". sure, you'll grab some debris, but it can be removed or just 'spread out' and disced up.
Thanks for the great replys. I have not measured my rippers but I am pretty sure they go more than 3 inches. I used them in my garden (soft soil to start with) and they dug in very good.
I know I will pile up some grass and debris, but I will just lift up and keep on digging.
My diggers are held in place with pins, and cotter keys. Does anyone have problems with the diggers popping out. Seems to me if the pins stay in then the force will keep the diggers in.
   / Plow with BoxBlade?? #9
Your box blade theory will probably work. mine go in about 6 inches when tilted forward.
On another note, for the sake of anyone with a cultivated area, yard, garden field, whatever, be careful where you plant the "chufa". This is another name for nutgrass, and nutgrass is the EXTREMELY difficult and expensive to contain or kill. It absolutely will take over any area that it gets loose in and is left unchecked.
There's an old joke about the only guarenteed way to get rid of nutgrass...sell the farm.:p
   / Plow with BoxBlade?? #10
I have done it a couple dozen times. It works well unless you have really thick turf. With the rippers all the way down and the top link shortened, I can get about 6-7" deep after a few passes. The first time the edge of the box will ride on the unplowed ground. The next pass will let it ride deeper, letting the rippers sink in. I cover 5' at a time at a pretty good speed, so you can do a pretty big area in 30 min. or so. I have thought about installing a couple of extra rippers at a closer distance for the final coupe of runs in order to improve tillage.
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
2005 International 4300 Telsta Telescopic Bucket Truck (A52377)
2005 International...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
