Does your plow have a leveling adjustment -- or do you square it up with your hitch?
youlll need to search about setting up a 2 bottom if you dont know how.
the quick verison
on flat ground (pavement is recomended)
1) block left tire up ~6"
2) level plow side to side.
3) level plow front to back
4) offest plow so the heal side of the share is roughly inline with the inside edge of the right tire.
durring the second pass you can start with adjustments. bottom of the furrow should be flat, the rolled sod should be equal.
troubleshooting
if the plow doesnt want to bite on its own, tow down slightly (top link adjustment)
if the plow wants to dive and not run flat, its pointed down to much bring tow back up. (toplink)
if bottom of furrow is not flat, you need to adjust tilt (side link)
if inside row is narrow/wider than outside row, you need to swing plow left/right (away/toward) inside of the left tire.
most plows from this age are designed for 3mph. below 1.5 or so they wont flip the sod, above 5 they will roll it 360.
Pulling my 2x14 deerborn behind my TC33 is a HARD pull. takes 4x4 with diff lock and a well setup plow.
results look like
Plowing the garden - YouTube (although my sideshift is slightly off)
