Plow valve for a tractor
   / Plow valve for a tractor #1
tessiers
Platinum Member
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I have a 6 1/2 foot fisher plow mounted to the loader of my tractor. To angle it I mounted the fisher control valve to the tractor with 2 hoses that plug into my power beyond and then plumbed the plow as normal. All seams to work well, does anyone see any problems with this setup? I figured it is open center by blowing through the valve when it was closed and that worked. What I could not find is how many GPM the valve could allow to flow trough it? And I also could not find the pressure the valve was rated for? The tractor produces 5.4 gpm at 2050 psi.
   / Plow valve for a tractor #2
If you install a hyd gage in the system, you will at least know the relief pressure, by holding the lever in the extended or retract position. Are there any numbers on the valve?
   / Plow valve for a tractor #3
Don't believe you should have any problem.
I had a fisher mounted on a 3/4 ton PU and I could use the angle function to push the PU back out of snow banks when stuck, and that PU was heavy when loaded with sand.
Also you are not running oil all the time, just when activating the valve.
For sure you eliminate the need for any flow restrictors.
I have un plugged the backhoe lines before and it is obvious when the tractor system goes into relief, the plow valve does not do that. There is flow through the valve when it is plugged into the power beyond even when the valve is in the neutral position. Do they make a gauge that will plug into the quick connects? what will that tell me? No numbers I could make out, I couldn't even tell which was in and out except I blew in one while pulling lever to lift blade and that was inlet.
   / Plow valve for a tractor #5
You can take a WAG (wild *** guess) at the max GPM for the valve by the port sizes on the valve.
UNUSED SWICT 66" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 66"...
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2017 Volkswagen Jetta (A50324)
2017 Volkswagen...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
