please help
   / please help #1
bob the geezer
cowgill mo.
john deere l-130
my jd l-130 will only run while spraying with carb cleaner. i have replaced pump,lines, and filterto no avail.
   / please help #2
:welcome:
I'm going to move your thread over to our John Deere section to see if we can find you some help.
   / please help #3
bob
:welcome: to TBN
On first blush, sounds like a fuel problem that you need to track down..
What is the history of the tractor, and the fuel that is in it? The more detail the better..
With fuel line off the carb, will fuel pump through the line?
   / please help #4
Here is a link to a pdf on the Kohler carbs. http://gardentractorpullingtips.com/pdf_files/kohler_carburetor_reference_manual_tp-2377-e.pdf Scroll down to section 5.12 if you have the Keihin carburetor.
I happen to be working on my L 130 with similar issues right now. Mine has the Keihin BCH 24 053 61 and will idle smoothly if fully choked. Cleaned it up this evening and will reinstall it tomorrow. Might be able to shed a little light on this in the next day or two.
   / please help #5
You will want to know that the solenoid at the bottom of the carburetor actuates when the key is on. Set the park brake , turn the key to on and listen for the click.
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
UNUSED Rustproof Galvanized Wire Mesh Rolls (A53117)
UNUSED Rustproof...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2014 Ford F-550 Altec AT37G 37FT Bucket Truck (A51692)
2014 Ford F-550...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
