please help with my oddball trailer
   / please help with my oddball trailer #1
oldboyscout
ne PA
Kubota B2620
I'm starting on a special purpose trailer and need some advice. i'm building a small trailer to carry camping gear to be used on and off road. I have a 42" x 60" box of 16g sheet metal, and started a frame of 2"x1/8" angle. I figure the usual utility trailers seem to be fine this way. I need to carry a few hundred lbs of gear plus the same in kayaks on top, no more than 1000 lbs. Does this sound like it will be okay? I'm trying to keep it lightweight to pull with a 4cylinder jeep, but still want to make it reasonably strong. I'll post pics tomorrow
   / please help with my oddball trailer #2
Consider wide, flat fenders. A wide flat surface above the ground to set up the camp stove or BBQ on is very nice as one gets older.
Cam
   / please help with my oddball trailer #3
Do a Google image search for
expedition trailers
for lots of ideas.
Bruce
   / please help with my oddball trailer #4
Consider torsion axle instead of a conventional axle, not for the better ride but for the added ground clearance. The torsion axle mine had were only studs so there was no beam going all the way across the trailer.
   / please help with my oddball trailer #5
I think I'd use tubing instead of angle. It's more rigid. 1/8" isn't very thick and it's probably a good idea to have a little bit of weight or the trailer would bounce around too much. Also consider using larger diameter tires. They don't spin as fast and are easier on the bearings.
this is based on the expedition trailers. In fact I already have an M416, but it is too heavy with 4 people in a 4 cyl Jeep. So I want to build a very lightweight version. Not planning on doing the Rubicon with it, just rough roads. I have a common utility trailer made of 1/8 x2 angle, so I thought it's doable. I'm wondering if I add diagonal bracing to the frame and unitize it with the box if it will be good enough.
I had an axle made the proper size to use the same 31's that are on the Jeep.
Good point about the flat fenders. I have a set of round ones, but I'll fab something flat instead.
   / please help with my oddball trailer #7
You could use the light weight angle and regardless of size of angle, you do need to put in some cross bracing to stiffen up the frame. Unitizing the box would make for a very strong frame just like a crane boom, light but strong. You didn't say how tall the box is going to be, but you may want to consider putting a box frame of light weight angle around it and welding the whole thing to the trailer frame. 1 1/2" x 1/8" angle run at the perimeter of all the corners of the box and tied back to the trailer frame would make it much more capable and not add a significant weight factor. 2 each 20 foot pieces of light weight angle would be all you need and be less than 100 pounds of weight and by having that frame around your steel box it is going to add some stiffness to it as well to allow top carrying on it without damage.
   / please help with my oddball trailer #8
You can probably buy the flat fenders at Northern Tools or TSC cheaper than you can make them...
Did you consider aluminum?
aluminum would be great but I can't weld it. I'll have to look for flat fenders big enough for the 31's-I haven't sen any yet
I was planning on 1x1 x1/16 tubing around the top, with corners braced with angle also-hence the unitized idea. The box is 18" deep.
   / please help with my oddball trailer #10
A place near me sells fenders and makes them. They had some huge ones the other day they made for a customer who did not follow through.
New/Unused Pallet of 22 Straps (A48837)
New/Unused Pallet...
2005 Massey Ferguson 481 80HP 4WD Agricultural Tractor (A49346)
2005 Massey...
2013 Ford Escape SUV (A48082)
2013 Ford Escape...
2006 Ford F-150 Crew Cab Pickup Truck (A48081)
2006 Ford F-150...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2016 Nissan Sentra Sedan (A48082)
2016 Nissan Sentra...
