Please help!!! the stump is winning!
   / Please help!!! the stump is winning! #1
Sparkeee24
Bronze Member
Washington
Kioti RX7320 PCC
Howdy everyone! I took on a project far beyond the couple hours I thought it would take. The local deere dealer is letting me demo a 110 TLB, it's awesome! So there is this stump... cottonwood... trunk is about 4 ft diamater. My dads gonna KILL ME!! I have about an 18 ft wide crater, 4 ft deep all around. And it shakes, but not like it would come out. Do Cottonwoods have a root going down? or just to the sides? Any and all help would be appreciated!!! I was trying to surprise my dad after a trip he took to morn a passing family member. I have till monday with a shovel. till tommorrow afternoon with the tractor. I think I will have to call in to work too /forums/images/graemlins/frown.gif An awesome going project, and I got in over my head. Thanks for any and all help!!! Brian, Sparkeee24
   / Please help!!! the stump is winning! #2
Try digging as far under it as you can. Then get out the hose and start using water to clean away the dirt from the roots. Look for the big roots that your Backhoe can't break and cut them with a saw. Keep working under it. According to one web site I googled Cottonwoods are supposed to not have big tap roots. I spent 4-5 hours on a Douglas fir stump this weekend. It took a while but it eventually came out. I didn't have a backhoe either. /forums/images/graemlins/blush.gif
   / Please help!!! the stump is winning! #3
I have had good success by digging a ramp down one side with the fel to get underneath some nasty stumps. If it's moving, you're close. I have used water to clean the roots as well, although it really gets messy. With a JD110 you should be able to dig a ramp and get underneath it no problem. I have also used chains to pull them over into the ramp so I could drag them out.
As far as the crater.... there's no gettin' around it. That's half the fun of owning a tractor, cuz then ya get to fill it back in when you're done. /forums/images/graemlins/laugh.gif Just make sure you're not pouring a concrete slab where the tree was.
Greg
   / Please help!!! the stump is winning! #4
Why not just pour diesel on it and let it burn?
   / Please help!!! the stump is winning! #5
I also use the ramp method, usually digging a ramp down from opposite sides deep enough to dig slightly under the root ball works.
   / Please help!!! the stump is winning! #6
At times like that, I'm reminded of those immortal words from Jimmy Walker.
DY-NO-MITE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
   / Please help!!! the stump is winning! #7
If you have access to a come-along or a chainfall, I like to get ahold of one of the bigger roots and tie off to a tree or truck and pull at the root with a direction that would be similar to twisting the stump in place. It works well sometimes when I can't get the tap root to break by rocking back and forth.
   / Please help!!! the stump is winning! #8
If your BH doesn't have enough reach to curl under the stump with the bucket then the next best thing is the ramp. It does involve a bit more seat time though.
Sounds like a good title for a song. "I fought the stump and the stump won." /forums/images/graemlins/grin.gif
The stump is still fighting!! but it is a losing battle for the stump. My roommate was so awesome as to spend the afternoon digging down at the sides. So I took a pick axe to under the root ball, and it appears this is working. am finding 1" - 3" thick roots every now and then, and hacking them with my hatchet (sharpening every so often). but now the pick axe is cutting under it nicely. just alot of work for such a little stump. I mean, it's only like, 4 ft across, how bad could it be? famous last words...
Thanks for the advice folks! I am in an un-incorporated county, and our land is about the last piece of "hobby farm" size acreage around anymore. Burning is out of the question. Burn ban as well. Thanks again everyone! Brian Sparkeee24
Bye the way, I would recomend the LTB 110 to ANYONE looking for a smaller TLB. It rocks!
   / Please help!!! the stump is winning! #10
Sparkeee24-
What part of Washington are you in?
Pics of the stump would be great.
Bonehead
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53473)
2019 Energreen EVO...
2005 KENWORTH T800 (A53843)
2005 KENWORTH T800...
2006 Pierce Dash Fire Truck (A51692)
2006 Pierce Dash...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
