Comparison Please help please advise
   / Please help please advise #1
John Tractoring
Estill springs, TN.
none
Friends I am having to decide between a brand new TLB Kioti CX2510 Vs Kubota B2601 TLB. Everythings the same implements, tires filled, and etc. Except the Kioti will have the HST assist which to my knowledge is not available on the Kubota. However, the Kubota has 3 range hydro instead of just 2 range like the Kioti. The price is about the same only about an $80 difference. Same deal $0 down $0 for 84 months. I need to decide this week as I am driving my wife and myself nuts. On paper to my eyes the Kioti beats the Kubota, but I would really value your opinions on the tractors. As many of you have probably owned or had more seat time in them than I have. I have test drove the Kioti and loved it. I am test driving the Kubota Monday. To be exact the Kubota that I am test driving is a 2401 gear as they don't have the 2601 in yet for me to test drive. But I figured it's the same frame and should be the same hydrolic pump the best I researched, so I can get an idea of the loader speed, ergonomics, and etc. Please advise me on what you would do pros and cons. Thank you
   / Please help please advise #2
The Kioti CX2510 is a brand new model just released in August 2020. So probably not a lot of owners can respond for that tractor model. If it was just these two tractors to choose from I would probably get the Kubota B2601, due to mainly three range HST and more lift at the 3pt hitch and slightly improved loader specifications. The Kioti has the higher hydraulic flow by 20% and the HST assist is quite nice. This is the first time I hear Kioti has something like the Kubota HST Plus. This is a new concept in HST technology. Both Kioti and Kubota have very good reliability. I really can't think of any serious negative points about these manufacturers.
For me the Kioti CK2510 is a three range HST that competes much better with the Kubota B2601, and has a 7 year track record of successful design. What ever you decide, get your tractor order in quickly before annual spring orders start in Mid March.
   / Please help please advise #4
Which one seems to fit you the best. Which one has the better location of all the controls. Which one has better customer support. Yes - go in there - have a look at their maintenance department and have a informative talk with their maintenance manager.
   / Please help please advise #5
In addition to all the above I'll add that I'm very leery of putting money into the introduction year of anything. I also like the three shift ranges of the Kubota. Distance to the dealer and support quality should weigh heavily into your decision,, though.
   / Please help please advise #6
I also prefer a 3 range HST but must stress that with many of the smaller HP models find that the high range has been useless! At the same time I have found that a properly set up 2 range HST has performed just as good and in some cases better than the 3 range.
This meaning I would test run anything I was looking at for an extended timeframe and evaluate what if anything that 3 rd range was good for. Only being able to use it for going down the hill faster than a 2 range would not make it worth much in comparrison.
What the cut off for it’s usefullness is or what size machine I will let for you to evaluate on your own as I don’t want to insult or get into arguments here over it. But do understand that my 20 hp 2 spd ran circles around my friends 25 hp 3 spd and I didn’t shift ranges the entire day. Each gearset will react differently based on how it was designed and what the actual useful range is.
Test drive everything preferably while working the machine and do not use the geared version of any tractor to get a feel for anything other than physical size. Gear tractors perform way different than thier HST counterpart and doing so will most likely result in disappointment when you find out how much less your HST version performs compared.
   / Please help please advise #7
The high range on the Kubota B2620/2601 is actually useful for more than just roading. When I get a light snow and don't want to blow it, I can use high range plowing with the loader.
The one I rarely use is low range. I can box blade or carry gravel up my steep hills in medium range no problem.
   / Please help please advise #8
A very good point. I must admit, my 3 range Kioti tractor is used 95% of the time as a 2 range tractor. I rarely use the 3rd or high range, unless I am driving it on the road. So I should not be condemning any 2-range tractor, when I am using only two ranges.
And that is? Kioti TLB with 4 foot heavy duty box blade tires filled and hst assist installed and delivered 27,186 Kubota TLB with heavy duty 4 foot box blade tires filled and I pick up 27,130 to my knowledge the Kubota dont have an hst assist option. sorry if I posted this in the wrong spot ]
I paid under $19K for mine including a 4' tiller. Closest dealer though seems to be Haney's in Athens.[/QUOTE]
   / Please help please advise #10
Can someone point me to some info on the Kioti HST assist? Can't find any info on it at all.
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
King Kutter 6' 3 pt Mower (A50515)
King Kutter 6' 3...
2017 SANY SY365C LC EXCAVATOR (A51242)
2017 SANY SY365C...
CATERPILLAR 259B3 SKID STEER (A51242)
CATERPILLAR 259B3...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
