PLEASE HELP! OWER TROUBLE
Status
Not open for further replies.
   / PLEASE HELP! OWER TROUBLE #1
lawnduster
Bronze Member
Central NH
CAT 966, Case 580
Just truesday 7/05/05. I finally got my 70's craftsamn all ready to go for the first ride. I took mthe first ride it ran very strong, and wnent pretty fast. I had the throttle a wider open than it was amde to go (i kinda too the governer out of play)Every day I rode it and it ran very good. But I have no real way of controlling the throttle so it revvs when I put it in Neutral and when I activate the clutch. Up untilk sunday I had ran it in third since it is only a Four speed. 3 forward one backward. Sunday, I went for a ride down my street in second gear. ABOUT 100 yards from my driveway I noticed it started to revv kinda high. I t continued a little bit more and shut down. Noiw I cant even get a putt putt out of it even with starting fluid. On sunday I also changed the oil earlier in the day and put new spark plug in. I may have filled the oil tooo much could this be part of the problem. does anyone know what the problem may be.
i ALREADY TOOK THE HEAD OFF and clean both the head and the cylinder walls and the top of the piston. it still don't run, but it backfires which it did not do before.
   / PLEASE HELP! OWER TROUBLE #2
If it backfires it is getting fuel, fire and combustion..it sounds like it is out of time, maybe a slightly sheered keyway.
   / PLEASE HELP! OWER TROUBLE #4
Thread closed. Refer to the other thread in this forum with the same subject.
Status
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2011 Genie GRC-12 Man Lift (A53117)
2011 Genie GRC-12...
