Please help a newbie out.
   / Please help a newbie out. #1
amashinga
Bronze Member
Hi folks,
I bought my first tractor a few weeks back. I have limited means, so its fairly old, a small ford 1100, with an older model JD FEL on it. It was sold to me with full disclosure, and the seller did inform me that their was a hydraulic leak around the area of the control valve. I have absolutely no previous experience with hydraulics, but I am ok with mechanics, I have a shop, and I have never had a problem fixing anything I put my mind to, so I bought it anyway.
Last night I pulled the control valve and took a look. It is a dukes fluid power make, I believe the company was bought out. What I saw surprised me. There were no signs of any o-rings, gaskets or seals at all. This is on the spools, the hose connectors, the detent plugs or end caps.
What should I be seeing when I pull this apart ?
Thanks.
   / Please help a newbie out. #2
Is this like it? BushHog Parts Diagrams
I think Danfoss bought Dukes.
You might consider just buying a new valve - go to a joystick type if you can.
   / Please help a newbie out. #3
Yes, Sauer-Danfoss bought out Dukes. I believe you have to source parts from Berendsen now.
   / Please help a newbie out. #4
You may luck out on this. In my situation (dukes valve) I couldn't come up with the right numbers and finally order, received and will hopefully install tonight. Price wasn't too bad $179.00 from Northern tools. And it looks almost exactly like the old dukes. Good luck.
   / Please help a newbie out. #5
I've seen metal on metal spools... when they wear to the point of leaking.. you repair by replacement.
soundguy
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
WEATHER GUARD TOOLBOX (A52472)
WEATHER GUARD...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
New Holland LX885 Skidsteer (A51573)
New Holland LX885...
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
