Playground rope project
   / Playground rope project #1
MillWeld
Durham NC
Ford 641
I have a friend who has has asked me to help install a rope around 3 large trees in his yard for his 5 yo daughter to play on. The idea is to have 2 parallel ropes around the trees, the lower one to stand/walk on and the upper one to grab hold of so she can walk hand-over-hand between the trees. I initially thought of using wire rope inside a garden hose but that may be difficult to install and stretch tightly. If we use rope it must sag minimally and hold up to the weather and be thick enough to make a comfortable grip. Any ideas on a material to use?
Thanks,
Bob
   / Playground rope project #2
What about using a slack line Gibbon Slacklines on the bottom and rope (box stores will sell rope by the foot, or precut) on top. Tie one end with a clove hitch and the other end with a taut-line hitch so you can adjust it.
   / Playground rope project #3
Metal cable on strainers attached to the tree would work well and can be quickly & easily adjusted if it sags.
   / Playground rope project #4
One thing is what the rope will do to the trees long term, I would think wisely on this but you can do it. Might look into ratcheting straps the 2" wide ones can be run and tightened down. There are some YouTube videos of guys on slack lines and ratcheting straps both doing pretty slick tricks.
Slackline Tricks Compilation ... it´s all about Balance - YouTube
Vertical Jump - Trick in a Minute - YouTube
I would not suggest the garden hose cable direction as the cable and hose can rotate independently and be harder to hold. Look around for some good turn buckles that you can run heavy rope thru and have them inside the trees, like a boxing ring. so tightening the turnbuckles will put greater tension on the ropes.
Mark
   / Playground rope project #5
Soft nylon rope like they use on docks to tie up boats. It weathers well, gentle on hands and very strong. 7/8", 1" etc..
Our local discount tools sells it. A marina would too.
   / Playground rope project #6
I just researched a fence project and found that the best option is natural manilla rope. It comes in all sizes, is resistant to rot and UV rays. Take a look at my thread in regards to the fence. The man made options did not seem to hold up to the weather. Especially UV rays. Good luck on the project.
   / Playground rope project #7
I'd use Dacron rope, very durable and low stretch.
How long do you expect to leave this up? If more than a season, you have to worry about damaging the trees by girdling them. It's kind of counter-intuitive, but the healthiest way for the tree to attach a rope long-term is to use an eye-bolt.
   / Playground rope project #8
Ropes lead to accidental hangings... Don't use them.
mark
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A54865)
2006 Volvo VNM...
40006 (A53422)
40006 (A53422)
30046 (A53424)
30046 (A53424)
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
