play in steering - 1500D
   / play in steering - 1500D #1
tmoritz
St Paul, MN
Yanmar 1500D
The play in the steering of my 1500D is exactly half a turn of the steering wheel. I assume that's waaayyyyyyy too much. Trying to go straight on a road (which I did for the first time a day or two ago) involves tons of steering. Could others tell me how much play you have or find acceptable? Thank you much!
   / play in steering - 1500D #2
You can adjust the play to a small extent, but it's only an hour or so to open it up and look at it. If you replace bearings that are wearing and fill the reservoir with grease you might save yourself from buying a column assembly for a couple hundred $. When the bearings go, they do a lot of damage.
Your advice is much appreciated, LMTC. Thanks!
   / play in steering - 1500D #4
If you haven't already, check for a loose steering arm on the left spindle.
My 1500D had a loose steering arm which resulted in a lot of play.
Thanks Boonesmith. I'll check it out.
   / play in steering - 1500D #6
Check the ball joints in the linkage too....
Will do. Thanks.
JOHN DEERE Z997R LOT IDENTIFIER 227 (A53084)
JOHN DEERE Z997R...
2020 Bell TC-11A Crawler Carrier (A52384)
2020 Bell TC-11A...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
(APPROX 80) 2" X 3" X 19 3/8" ANGLE IRON (A51247)
(APPROX 80) 2" X...
