Plastic vs. steel culverts in 36" size?
   / Plastic vs. steel culverts in 36" size? #1
jenkinsph
Super Star Member
somewhere usa
Deere 110tlb, 4520, x749, L130
I am looking to bid a large job today and need to add a 36" culvert to access the property. I am considering a plastic culvert but don't have any experience with them, what are the pro's and con's compared to the galvanized culverts I normally have used?
   / Plastic vs. steel culverts in 36" size? #2
I maintain 50 miles of rural roads. Have no idea how many culverts are involved, never tried to count them, over 100 I'm sure. I've used plastic since 1992. I'm talking about dual wall plastic, corrugated outside, smooth inside. In sizes from 12" up to 48". My provider builds 20' or 30' with bell/o-ring ends so they slip together without needing a band.
Only time I use galvanized steel is if I get into very large size above 48". Then it's more cost effective to use steel.
I have zero complaints regarding plastic.
Their lifespan is beyond my imagination. They are a lot less likely to wash out. I've not replaced any for that reason. Originally rumor had it that varmits would eat thru them, but I've never saw that.
Very easy to handle. Usually I'm working by myself. With a 36", if you have to put two pieces together you'll probably hafta throw some dirt on the first piece to hold it and then use your hoe to push the second one on. For smaller pipe I can usually slip them together by hand.
Up until two years ago I'd never had one burn out. I bragged about that to a local farmer a couple years ago and then lost one due to fire. We have a lot of idle farm land here, Conservation Reserve Program. One method of maintenance is to burn it off. This one had a thick layer of waterway grass that ran right up against one end. Got the plastic started burning and then used it as a chimney and burned out the entire culvert, 40' of 18". All that was left was small piles of melted molten plastic.
If you go plastic, you'll never go back!!!! Good luck with your project!!!
overszd,
Thanks for the detailed response, I will check to make sure the supplier is quoting the same or similar design as you mention in double wall.
   / Plastic vs. steel culverts in 36" size? #4
Good information, we have been using metal and need to replace one this spring on a dam levy inlet that's too short.
   / Plastic vs. steel culverts in 36" size? #5
We have a bunch of plastic on our farm (18" smooth inside, corrugated outside IIRC) and its been great.
Aaron Z
I received a price of $45/ft for 36" double wall plastic culvert, is this inline? I need this asap to cross the ditch to do the main job of installing the irrigation system and field leveling.
   / Plastic vs. steel culverts in 36" size? #7
Having designed and built a whole lot of roads in my professional career, your question is not a simple one to answer because there are a lot of variables. Generally speaking though, plastic certainly has an advantage over corragated metal on the corrosion resistance side. However, bedding and backfilling are probably a little more sensitive on the plastic (HDPE) versus metal (CMP).
You can find a wealth of information on installation pratices on the websites of both industries.
   / Plastic vs. steel culverts in 36" size? #8
Another vote for plastic -- I've had good luck with it. Dual wall smooth bore N2 (ADS or Hancor) is what I have been using. The pipe specs will state the minimum amount of cover, but normally it's based on a scale factor of diameter as a rule of thumb.
   / Plastic vs. steel culverts in 36" size? #9
That's a little higher than I'm paying. But I'm under governmental contract which probably knocks off a little.
   / Plastic vs. steel culverts in 36" size? #10
Addding to jtgoku's comments, and my own personal experience with
a 24 inch twenty foot long plastic ribbed culvert-
Unless the culvert is buried deeplyMore than 36 inches below grade
it will want to float out of the ground as my mine did.
It-meaning the plastic culvert became useless as it was more
bouyant than the surrounding soil due to its light weight and
the frost heaving it out of the ground.
It was replaced with a 20 foot metal culvert by the original municipality
that granted me permission to replace the first smooth bore rusted out steel pipe
with a ribbed plastic culvert.
2023 AIRMAN PDS 100S T4 (A45333)
2023 AIRMAN PDS...
2006 STERLING  L9500 MIXER (A45046)
2006 STERLING...
CHECO HYDRAULIC GREASE INJECTION UNIT (A45333)
CHECO HYDRAULIC...
2025 Kivel 48in Skid Steer Forks and Frame (A44571)
2025 Kivel 48in...
2016 Ford Explorer AWD SUV (A44572)
2016 Ford Explorer...
(2) Planter Wheels (A44502)
(2) Planter Wheels...
