Plastic spray tanks...junk?
   / Plastic spray tanks...junk? #1
Wacky
Veteran Member
West Virginia
2010 GC2610
I purchased a 25 gallon spray tank for herbicides a year ago. It is from a well known vendor. I bought it knowing it was ALL plastic, except the pump. The wand and boom have steel tubes, the rest, all plastic. When I used it last at the end of the year the nipple for the wand broke off, the nipples for the boom and wand are side by side. So, I called customer service and told them I need a nipple for the pump that broke on mine. They told me they were going to send another one out.....complete unit.:eek: I told her I only need the nipple for the pump. She said don't worry about it. And didn't want the old one back(probably because of the contamination from what ever was in it). I told her thanks and hung up. Called the parts line and ordered a nipple for the pump. Installed it this year and it worked fine. Now the wand was leaking profusely where the trigger is now!! :mad:I opened the new tank and took the wand out of it to use and wouldn't you know.....it leaks!!:mad: At first I started to call, but than thought it wasn't worth it anymore.:confused2: The question I have is does anyone make a GOOD sprayer that will last at least 1 yr??:confused3: That won't break the bank???
   / Plastic spray tanks...junk? #2
Mine leaked at the wand, but I know why, I drained the tank but the wand still had water in it.. froze, and burst. Found a new one for $6 at Race Brothers Farm supply..
James K0UA
   / Plastic spray tanks...junk? #3
Good questions.
I have a 15 gallon, 1 GPM FIMCO sprayer, purchased for $89 at TSC, that's made it through one year without any problems.
I decided I wanted additional tank capacity, so I purchased a 25 gallon, 2 GPM Countyline from TSC for $149 this spring. The TSC salesman told me that the sprayer was a re-branded FIMCO. I don't have any idea as to whether this is true.
A plastic Y garden hose fitting developed a leak after spraying one tank. I replaced it with a metal fitting and then the pump quit after spraying the third tank. I returned the sprayer to TSC and obtained a replacement. The replacement has made it through two tanks without a problem, but I'm not confident about its future performance.
So to shorten your list of possible candidates, strike Countyline.
Steve
   / Plastic spray tanks...junk? #4
I have a FIMCO 14 gallon rig and it works fine - about 4 year old.
   / Plastic spray tanks...junk? #5
We have a 16 gallon sprayer from Northern Tool. Working great for 4 or 5 years now...
Have fun and stay safe......
   / Plastic spray tanks...junk? #6
I used my sprayer yesterday and it turns out it is NOT Fimco but rather North Star which I bought at Northern Tool years ago.
James K0UA
Freezing is not an issue w/ mine it is in a heated garage. I looked around but cannot find anyone that makes a sprayer w/ brass fittings, why is that? Do they corrode or something from chemicals??:confused:
   / Plastic spray tanks...junk? #8
No brass is more expensive. My first sprayer the tank cracked. So far so good on the second one. Both fimco.
I called and they are sending me a new wand. I can't see spending $130 on another plastic sprayer and have the same issues. I guess I will just keep piecing this one back together until the tank cracks or something major.:(
   / Plastic spray tanks...junk? #10
I have a 50 gal Fimco... ive had it for about 8-9 years. Never had any problems cept for a cracked filter bowl (i forgot to drain it before winter). Has always worked great. and it too is plastic. I believe all sprayers are plastic....at least all that ive seen for utility tracrors/atv's
1999 Case 90XT Skidloader (RUNS) (A50774)
1999 Case 90XT...
2011 Bobcat S630 Skidloader (RIDE AND DRIVE) (A50774)
2011 Bobcat S630...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
2017 Ford Expedition 4x4 SUV (A50324)
2017 Ford...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
