Plastic Pallets Uses
   / Plastic Pallets Uses #1
K5lwq
Elite Member
Mineola, TX
Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
I am looking for ideas for making a carryall out of a plastic pallet. As I was playing around with the idea, I thought of several things I do with these pallets. I can get these at work, so I might just bring home a couple and have them for specific uses.
First question is would you add plywood or something to the floor?
I would like to have one that is just a platform to stand on while trimming limbs.
I also would like one with a cover over it to house my generator. Would make it nice to use if I loose power during a rain and not have to worry about it getting wet.
What other ideas do you have?
   / Plastic Pallets Uses #2
Plastic is slick, so whatever you use it for, especially standing on it, might be an issue.
They are great to put stuff on that is stored outside, to keep them off the wet ground.
David from jax
As far as a generator cover, great idea! You could take two of them, add four pipes of equal length between them, bolted together, and wallah, you have a movable generator pallet with a cover. Plus you can pick it up from the bottom or top, lol. Make sure you leave plenty of space around the generator to allow air flow for cooling!
David
   / Plastic Pallets Uses #3
I sometimes use the really cheap plastic skids to cut apart branches with the chain saw. If you hit the plastic, no problem.
   / Plastic Pallets Uses #4
You could use two of them to construct an inverted-V structure in your field.:)
Steve
   / Plastic Pallets Uses #5
I use them to set my implements on instead of leaving them in the dirt since I don't have gravel on the shed I use for storage.
I have this style of pallets:
Some great ideas although the wife might not approve of the inverted-v structure. :)
Thanks for the ideas!
   / Plastic Pallets Uses #7
someone near me has an open cell version and made a front porch and railing. I'd use them to get my stuff off of the concrete and dirt.
   / Plastic Pallets Uses #9
I have a hot tub on my back porch... I recently got one of those plastic pallets & cut a hole in the porch & lowered the HT onto one..
Works great keeping it out of the dirt..
So go gettcha a hot tub.. tell the wife you needed to use up the pallets..Lol
2011 DRAGON PRODUCTS 150BBL ALUMINUM VACUUM TANK TRAILER (A45046)
2011 DRAGON...
2014 Dodge Charger Sedan (A44572)
2014 Dodge Charger...
Case-IH 586G (A44501)
2012 KENWORTH T800 FLATTOP SLEEPER (A45333)
2012 KENWORTH T800...
Ferris IS 4000 (A44502)
Ferris IS 4000...
2011 KENWORTH T800 DAY CAB (A45046)
2011 KENWORTH T800...
