Plasma Cutter
   / Plasma Cutter #1
chowl
Bronze Member
Houston, Texas
2005 JD 4720, 2004HPX 4x4 Diesel Gator, 2005 HPX 4x4 Diesel Gator, 4x2 E-Gator, JD 737 Z-trac, JD 997 Z-trac
Would like feedback on a Thermadyne Dynamics Cutmaster
51 plasma cutter. Good or bad any info will help before I make the jump.
   / Plasma Cutter #2
If you don't get the enough feedback here you can try the Hobartwelders website. There are pro weldors who can answer most equipment questions.
   / Plasma Cutter #3
web page
Might try this site and ask for Uncles advice! /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
   / Plasma Cutter #4
I bought the Thermal Dynamics Cutmaster 51 last year from
Indiana Oxygen. About $1600.
I love it. It works great. This is my first PC, so I can not
compare it to others by personal experience. I often cut
up to 1/2" A36 steel, including holes.
   / Plasma Cutter #5
TD 51 should be a good unit. I owned a TD 38 for three years and then six months ago I traded it in on a Cutmaster 81. I needed more power, 'cause I frequently mount the torch in the NC cutting table I built. This doubles the power requirement for a given gauge. I used the 38 real hard for those three years and it alway worked fine, never shutdown from overheat or anything, and gave a very nice fine kerf if you were patient. The real limit of that machine when using the torch handheld was about 1/4". In the NC table, I could not cut greater than 1/8" with acceptable quality.
Overall, Thermal Dynamics is great product. Just make sure you buy a big enough one to do what you need done. If in doubt (or if you are doubting the manufacturer's ratings) take some steel to the dealer and ask him to let you cut thru it. And, try curves instead of all straight lines, it seems to take more power or lower pass speed. See ya...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2024 KMC 7406 (A53084)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
