I have a Primeweld plasma cutter CT520D it’s a non pilot arc machine. It works great but it would be nice to have the pilot arc. Especially after using the plasma cutter at work. I thought I read where someone was able to convert non pilot arc to pilot arc? Is this possible? If so is it expensive? Is it worth doing? Thanks
Converting a non-pilot arc plasma cutter like the Primeweld CT520D to a pilot arc system is technically possible, but it can be complex and may require significant modifications to the internal circuitry. The process typically involves adding additional components such as a high-frequency generator or modifying the torch to enable the pilot arc feature. This conversion can be costly and may require specialized knowledge in electronics and welding equipment.
Given the expense and technical expertise needed, it might be more practical to invest in a plasma cutter that already includes a pilot arc, rather than attempting a conversion. On the other hand, if you're the type who enjoys challenges, like trying your luck at a casino
https://bacanaplaycasino.net/ taking on such a project could be an exciting endeavor.
