Plantings for weed control/suppression
   / Plantings for weed control/suppression #1
HawkinsHollow
Veteran Member
SE TN
Branson 3015R
I cleared a bunch of land last fall. Well as spring and summer approached I got super busy building my shop and just let it go wild all summer. Needless to say it is now a JUNGLE of weeds. Some 7' tall and so thick you can hardly walk through it. I am slowly getting it under control now that the shop is dried in, but my goal is to not let that happen again. What sorts of things can I plant in the spring to keep the weeds down over the summer. If I am going to go through the work I want it to be easier to deal with and maybe be beneficial to animals, polinators, birds etc. I realize I am going to have to bush hog otherwise the weeds will take back over. I am looking for some sort of perennial that is better that a bunch of random weeds. Perennial so I don't have to do this every year. This land is in a creek bottom so it floods a couple of times a year. Any suggestions wise TBNers?
I just wanted to add that I considered doing buckwheat, but that is not a perennial. But worst case it would do that job for a year.
   / Plantings for weed control/suppression #3
I let the weeds do their thing... only mow once a year in late Feb. when no wildlife is using our "pasture". I will spray the Black Walnut trees during the summer (they are the worst weeds that I have). At this time in my life, I don't have a use or need for the pasture - that might change when (if) I retire!!!
   / Plantings for weed control/suppression #4
If you planted buckwheat, did you plan on harvesting it?
If not and you let it go winter would knock it down and it would reseed naturaly in the spring.
Thanks for your reply. It isn't really a pasture per se. It is a corridor through our bottom land around a pond. It is much nicer looking and more enjoyable when there are not 7' weeds everywhere. It is a work in progress still need to clear more. I am just tyring to plan and implement a strategy to keep this area looking nicer and more usable throughout the year.
No I would not harvest it. So it sounds like that is an option then.
   / Plantings for weed control/suppression #7
I just planted crimson clover on about an acre. Im using it for erosion and weed control. It's cheap at $60 for 50lbs of inoculated seed. With a seeding rate of 10-15lbs per acre.
It grows in thick and suppresses other vegetation plus its beautiful when its blooming and deer and bees love it. It grows up to about 20 inches tall. Its an annual but it reseeds if left alone.
Its worth looking into for your application. It might be too late to plant this fall but you can plant early spring.
Thanks for your reply! I like the idea of clover as well, good for deer and pollinators. It can handle some shade as well. This area is not wide open, has intermittent trees.
   / Plantings for weed control/suppression #10
Check with your Extension Office or other Ag specialists for a list of native, but low growing wildflowers that you can seed the area with.
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A48836)
2007 International...
Galvanized Pipe (A49251)
Galvanized Pipe...
2019 Bobcat T590 Skidsteer (A48837)
2019 Bobcat T590...
10ft Brillion Packer (A49251)
10ft Brillion...
2013 Dodge Grand Caravan SXT Minivan (A48082)
2013 Dodge Grand...
Fisher Snow Plow (A49251)
Fisher Snow Plow...
