Planters: Does this type attachment exist?
   / Planters: Does this type attachment exist? #1
hillbilly0310
Highpoint, MS
to be determined!
Hey folks, I'd sincerely appreciate you reading my post and affording me any information and input that you have. There's a vast amount of knowledge amongst the people of this board, and given the weather patterns (i.e., RAIN) and time-sensitive criteria of getting seed into the ground, I am desperately hoping to tap into the knowledge base around here. Again, I appreciate any help you can afford me.
I have a Kubota L4701 with 900 hours on it. We bought it new, and though I cannot complain too much as it has been a fine little tractor, it quickly became too small as we continued to clear, maintain and cultivate our land. Alas, it is what we have for the time being.
The terrain varies, but the maintained open areas consist of approximately 50% being steep to semi-steep hills ( by east Mississippi standards), and the rest being gentle rolling hills and flat bottomland. All total we have about 100 acres of maintained land, and we'd like to begin planting hobby farm crops (e.g., sweet corn, peas, beans, and maybe some sunflowers for the doves) on approximately 40 to 50 acres of the land that is most feasible for it.
As far as attachments that pertain to tillage and seeding go, I've the following: Lowrey 6 ft. disk, a 1 bottom plow, single shank subsoiler, Taylor 500 spreader, Woods 72" tiller, a 6 ft. cultipacker, six ft. 4 way landscape rake (on top of many other uses, oftentimes I'll use it as a sort of harrow to bust up clods or scratch the surface of newly tilled dirt that has been rained on) a 110 gallon boomless herbicide spray rig, and a 6 ft. bush hog.
I plant lots of grass for erosion control (mainly millet and rye grass), along with approximately 10 acres of food plots that consist of brassicas, oats, wheat, rye, peas, chufa, and more. I also plant approximately 2 acres of wildflowers on a biannual basis.
However, because we desire to plant larger plots of vegetables, we very much desire a planter that can primarily put peas, corn, and sunflowers into the ground (and in a hurry), but also have the secondary ability to use the same planter to drill grass seeds into the ground.
Does any such attachment exist? One where a 47 hp tractor can drill (preferably with minimal-to-no tilling beforehand) grasses as well as larger vegetable seeds like corn and peas?
We've put thousand and thousands of dollars into minimize and/or restoring topsoil loss on our sloping areas that resulted from poor logging practices as well as insufficient erosion mitigation measures from past land clearing, but the problem that we often run into (especially on the slopes areas) is in the multi-step process of planting grass and the process being interrupted by heavy rain. For example, let's say that I spray, then mow, then till and cultipack, but then rain interrupts the process of actual seeding and the final step of rolling in the seed, and then I have to start over at the tilling step: We lose lots of time, fuel, work hours (money) and also, sometimes, we lose topsoil too.
It seems to me like an all-purpose no till drill would've already paid for itself in lost production and topsoil? But does such a drill exist to where you can also utilize it for corn and beans, etc.?
I apologize for the question if it be a dumb one, but I've read and read until I'm blue in the face and most of what I've read pertains only to large agricultural settings, but the question still remains: Can I get a single attachment for the purposes explained above, or am I destined for needing 2 attachments; with 1 being for grass seeds (again, preferably no till) and 1 being for putting corn and beans in the ground?
I thank you again for reading and giving me and advice and input that you have.
Well Wishes to You and Yours,
HB
   / Planters: Does this type attachment exist? #2
In my amateur experience with food plots small seeds need sunlight to germinate. (I know wheat is drilled, yet a grass.)
That is why a Cultipacker pressing seed is superior to a Chain Harrow or Disc Harrow covering turf seed and Clover seed.
Have you considered mulching broadcast grass seed with straw, then crimping with a straw crimping implement? A Disc Harrow with the gang angles adjusted flat, lightly rolling over your land, might crimp straw fairly well.
VENDERS: tractor straw crimper - Google Search
Also consider a conservation plow of some type. Field Cultivator/All Purpose Plow/ light Chisel Plow is relatively modest in price.
T-B-N ARCHIVE: https://www.tractorbynet.com/forums/attachments/339095-dirt-dog-all-purpose-plow.html?highlight=
VIDEO: DIRT DOG ALL PURPOSE PLOW - YouTube
Here is a good source for small scale farming/gardening implements:
Buckeye Tractor Co -- Online
   / Planters: Does this type attachment exist? #3
Please enter Kubota L4701 into your T-B-N PROFILE, superseding TO BE DETERMINED.
   / Planters: Does this type attachment exist? #5
Not sure there is such a planter. Beans and grass seeds are not really spaced like corn seeds needs to be. When I was planting row crops asked on grain drill to use for soybeans and corn and was always told will notwork for corn like real planters will.
Have a suggestion for you on the grass planting, reach out to your county agent's office and see if they offer any help with no till planting equipment or if they are aware of any other agency that does. Then hire someone with tractor that is capable of pulling to do the planting.No till needs a lot of hp compared to tilled planters. Also find out if there is any federal money to help reclaim that land and to help pay for the planting of grass on those slopes. You will ask about pasture planting or hay planting. It took three years but finally got funding for mine. You will need a farm number for that funding. If you don't have a farm number again ask your county agent what office does that. All I can tell you here is they are across the hall from the county agent, may be same there. lol
2007 FONTAINE TRAILER CO. 48X102 SPREAD AXLE STEPDECK (A52472)
2007 FONTAINE...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
INSPECTION (A51573)
INSPECTION (A51573)
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
Duetz Power Unit (A50120)
Duetz Power Unit...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
