Dave5264
- Joined
- May 25, 2009
- Messages
- 376
- Location
- Near North Ontario Canada
- Tractor
- 08 Montana C5264, 2011 McCormick CX100 XS
Hi Folks, well, im planning now for the pasture renovation so i can solicit some input. Here's the scenario, 1st yr of the horse farm last year and ive got some work to do inthe spring.
Ground : 4 - 6" topsoil , below that unlimited pure blue clay, gets real muddy
Pasture 1 - 3/4 Acre, was our scrificial pasture in the wet fall we had, its 80% mud now (frozen till spring and covered in snow), chance of Hay growing again here slim to none.
Pasture 2 - 1 acre, was part of the 3 pasture rotation last yr, eaten down real low, some mud along the edges & by the gate. Chance of hay growing again 80% good, with some re seeding
Pasture 3 - 1/2 acre , Temporary pasture, reusable as is -- area will be re purposed any way in the summer
Pasture 4 - 3 1/2 acres, Brand new, fence posts in, will be fully operational by May. never been used, had good hay on it last yr.
I need to rejuvinate pasture 1 and 2, while easing the Horses on to the new very lush pasture number 4 in the spring (dont want them to founder on the spring growth).
Equipment= Box Blade with Scarifiers, FEL, Diamond Drag Harrows, manual broadcast spreader.
The Plan:
Preserve pasture number 2 from further damage, over seed in March with frost /snow sill on ground, May be harrow it a bit as the ground softens up ???
keep the horses in pasture Number 1 until End of April and suffer through a month of real bad mud (like we did in the fall) -- rotating occasionally to pasture numbre 3 (temporary).
Ween the horses into new pasture number 4 by May 1, then set to re-doing Pasture number 1 as the ground firms up/dries out: use the box blade & tines to loosen up the dirt over the whole paddock. Use the drag harrows to smoothen out. Seed it with hay (manually with broadcast spreader), re harrow it. let grow, keep horses off it for 3 months.
what say you? will my rejuvination / re seeding work ok like this.
The Plan:
