plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,375
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
My new residence is serviced by an old well. Circa 1995, 2hp motor, about 25gpm +/-. The existing bladder tank is shot, the system sometimes short cycles, plus it is .... old. So I've decided to install a new pump, motor, and constant pressure system.
My well guy advises leaving the existing 1" pitless adapter in place. He says it is "too much trouble" to change, as it requires excavation, blah blah. My pipe from the well to the house is 1 1/4. All piping in the (new) residence is 1 1/4. Except for tie-ins at each plumbing fixture.
After spending the $$ to do this, I'm leery of having a 1" section of *anything* in place, as it seems like an obvious restriction on flow. But my well guy says it is "no big deal." He says a short section of 1" is not going to be a noticeable restriction even though everything else is 1 1/4 lines.
Two other things: a) I also have a 250' run of 1 1/4 pipe to my shop, where I plan to add future 1" rainbird sprinklers for the pasture, and, b) the house was recently re-plumbed up to 1 1/4 lines as the original (smaller) pipe size caused pressure drop and volume issues.
I get it that doing excavation is not desirable, will tear up the landscaping, and could get expensive. (I do have a small backhoe.) But I'm leery of his advice that it is "no big deal." But I don't have any practical experience to draw from, so I can't evaluate whether it is truly not an issue or this is just work he doesn't want to do?
Any thoughts or ideas?
