Piranha tooth bar and palletforks.com forks
   / Piranha tooth bar and palletforks.com forks #1
Kevin Krieger
Corvallis, Oregon
Massey gc1710
Does anyone know if the pallet.com forks will fit over the piranha tooth bar? I'm going to order these and was wondering if the forks (clamp on) would work without removing the bar, or should I order the bar with a cut out notch for forks near the ends.
Are there any clamp on pallet forks that work over the piranha tooth bar?
   / Piranha tooth bar and palletforks.com forks #3
Best to ask Harry, I think. I would not expect clamp on forks to fit. The tooth bar does stick out from the bucket quite a ways.
The tooth bar made for the BX has space for the clamp on forks. If your bucket would fit the BX sized tooth bar, you should be good. <-- this applies to using Bxpanded clamp on forks, I don't know if the same can be said for the palletforks.com forks.
   / Piranha tooth bar and palletforks.com forks #4
We use our Yankee Warehouse chain-on forks overtop our PTB.
It required cutting grooves for the edge of the next tooth into the holders for the 2x4 upright rollback preventers, but that only took a few minutes with an angle grinder.
They work just fine though.
2015 ISUZU NPR 16FT BOX TRUCK (A52141)
2015 ISUZU NPR...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
Case-IH 370 Steiger (A50120)
Case-IH 370...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
