pipe dope
   / pipe dope #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
can you use pipe dope on hydraluic hose fittings ? i have some that wont stop leaking...any ideas ??? thanks bruce
   / pipe dope #2
I don't know the answer to your question but I wouldn't do it. I'd just get new fittings.
   / pipe dope #5
Hydraulic fittings are designed so that no dope is needed. The metal to metal contact does it all. But sometimes stuff goes wrong in the field, and so there is such a thing as hydraulic pipe dope.
You can use hydraulic dope but there are some rules.
First of all is to get the special type for high pressure hydraulics - NOT the type you use for water and gas service and other general plumbing. The hydraulic kind stands up to hot oil and stays plastic long enough for the pressure to force it into the gaps to be sealed....but soon stiff enough not to get pushed on through.
Next is that you generally only want to put it on the male threads and not on the first couple of those. The idea being to make sure that any excess dope is forced out of the joint as it is assembled. That also means that you shouldn't loosen and re-tighten the joint. Yeah, I know that it's hard to get the hydraulic fittings lined up right the first time. We all cheat a little on this one..... That's why we didn't put dope on the first couple of threads.
So you want to think twice before using it on any fitting that you may need to take apart in the future. Most hydraulic pipe dope is designed for permanent fittings. Sometimes taking it apart is necessary but involves careful disassembly followed by lots of cleaning of the threads (I use dental tools) to prevent chunks of dope from getting into the hydraulic circuit where it can wreck the close tolerance pumps and valves. The ones that advertise as making the joint reusable don't mention that they are depending on your having thought about the relationship of your hydraulic filtration to the flow path.....here's hoping they aren't being too optomistic.... Anyway, it's not a good plan to use the stuff on any fitting that you plan to take apart regularly.
But all of that is not to say that the pipe dope doesn't have its place. It does. Just think it through & keep your brain in gear.
rScotty
   / pipe dope #6
On a side note,.. pipe dope is ment for PIPE thread fittings,... not JIC or ORB.
   / pipe dope #7
Just bought Loctite 545...
Yikes, almost 40 bucks for a small bottle... What do they put in this stuff anyway??
   / pipe dope
thanks for all the help...i didnt use any pipe dope...took the fittings apart cleaned them to make sure their was no trash or dirt ..put them back together...tighter this time and they dont leak anymore....so thanks for all the help bruce
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
STORAGE FEES (A53426)
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
