Pins for 3ph lift arms on a GC2400
   / Pins for 3ph lift arms on a GC2400 #1
bakerg
Elite Member
Tilbury, Ontario, Canada
John Deere D110
This is the second time I have lost the pin for the lift arm on the 3ph.:mad: I found it the first time but this time it is lost in the snow so I had to make another one. The original clips are very small and I found they fall out easily so I drilled out the holes and install bigger clips.;)
   / Pins for 3ph lift arms on a GC2400 #2
Use cotter pins or like what kubota use on some of the pins. It looks and works like a key ring.
   / Pins for 3ph lift arms on a GC2400 #3
Good idea with the cotter pins-- those snap-in pins will pop right out if something hits them or catches on them just right. As low as those 3PH arms are, that sounds like what's happening. irvingj
UNUSED AGT QUICK ATTACH SEEDER DRILL (A51248)
UNUSED AGT QUICK...
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
Autocar Xpeditor Tri-Axle Heil Front Loader Garbage Truck (A51692)
Autocar Xpeditor...
2021 Polaris RZR 1000-4 (A52384)
2021 Polaris RZR...
