Pine sap on car...HELP!
   / Pine sap on car...HELP! #1
Henro
Elite Member
Few miles north of Pgh, PA
Kubota B2910, BX2200, KX41-2V mini EX
This is tractor related...kind of...as I had to move my daughter's car so I had more room for my tractor to get by it. I was making multiple trips...
I parked it under a pine and forgot about it, and it sat there for a couple days...
Daughter got back from vacation this morning and looks at the car and it is covered with a LOT of pine sap...roof, including two sunroofs...side glass, everywhere!
Is there a trick to getting this stuff off??? Metalic red 2002 Subaru Legacy GT...
Everything tried so far flopped. I wonder if diesel fuel or gas might work?
If anyone has any ideas please advise! That stuff is sticky and nothing seems to melt it, or soften it much...THe paint under it is a concern so we have to try to be gentle...
   / Pine sap on car...HELP! #2
Bill; I used to use diesel or kerosene to clean bad stuff off my paint. I know that won't hurt Ford paint. Look in the owners manual and see what it says, other than don't get the junk on there in the first place. /forums/images/graemlins/frown.gif On the glass, a razor blade would probably work. You might also talk to a car restorer, these guys have some pretty wierd concoctions, as do some of the detailers.
Good luck at any rate. /forums/images/graemlins/laugh.gif
Later; johnday
   / Pine sap on car...HELP! #3
WD40 works very well and has not hurt our paint at all.
Thanks Johnday, cowboydoc and Inspector507...we will be trying everything that anyone suggests. Hope something works on this local pine sap!
Anyone else have other ideas...please chime in. All help greatly appreciated...Never would have thought of WD40 on my own... /forums/images/graemlins/cool.gif
I think I tell the daughter to take her mother's car to work tomorrow and experiment a bit on her's...
   / Pine sap on car...HELP! #6
Henro,
The best overall remover I have found and used is called <font color="green">Goof Off. </font> It is available at all Lowes in small lighter fluid style cans as well as gallon cans. I have used is for tree sap and for tar, etc. on vehicles, and found it to work very well w/o damaging the paint or the clear coat. It should be applied in the shade on a cool surface, using a soft cotton rag which is changed frequently.
When you use any solvent to remove tar, sap, etc., the solvent will also remove any wax on the surface. So, it might be a good idea, after removing the sap, to wash the car with a good detergent car soap, and then give it a good coat of wax. I'm sure your daughter would appreciate that as we go into the Fall/Winter seasons.
   / Pine sap on car...HELP! #7
Henro: Down here in Florida when i get pine sap on the truck as long as it is still tacky I use baby oil and a paper towel works every time
   / Pine sap on car...HELP! #10
Denatured alcohol will take it off without harming the finish.
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
CAT 420D IT (A47477)
