pin and bushing or swivel joint
   / pin and bushing or swivel joint #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
With all the posts on homemade grapples using fabricated joints with pin, bushing and tube for bushing. I'm wondering about the swivel type joints used on cat 1 top links. these use a 1" pin and the ends can be bought pretty cheap. How well would these work for building grapples?
   / pin and bushing or swivel joint #2
Cat 1 toplink pins are 3/4", Cat 1 drag link pins are 7/8". Those swivel balls are a little sloppy and no means of pumping in grease. Still, I dont see a strong argument not to try using them though. Using them would save drilling a few large ID holes. Are you building a grapple?
Larry
I'm sorry, I meant cat 2 which is 1". I'm selling my L3300, I'm going to try to sell with the grapple that's on it. If it sells with grapple I'm going to buy or build another one. As for as being greaseable.......These same links seem to work just fine on the 3 point where they are exposed to a lot of dirt. Looks like these would make a ready made joint for grapple and they are proven to work on tractors. The swivel ball can be bought in a weld on to weld to grapple arm and a 1" top link pin can be used on the base. Should make for a cheap reliable joint from common parts and the ability to swivel should help if there's every any misalignment, also no machining.. Maybe some of the wise ones on here can tell me why its a bad idea, or did I think of something?
Flatbed (A51691)
Flatbed (A51691)
2003 Ford Ranger XLT Pickup Truck (A51692)
2003 Ford Ranger...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2014 FREIGHTLINER...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
