picture size
   / picture size #1
Mansker
Bronze Member
Edwardsville--Illinois
NH TC 33D / ford NNA
What is the max. size picture you can post without going over the 100000 limit? I posted an 800x600 and it said it was too big so I cut it down to 640x480 and it is still too big!
   / picture size #2
Most photo-editing software has a compression setting you can use. Play with that until the filesize gets under the limit.
You should be able to compress a 800x600 file enough that it still looks good for PC viewing.
   / picture size
I've been posting them and 800x600 and they were fine, now it won't let me, if I go below 640x480 you can hardly see the picture.
   / picture size #4
<font color="blue"> I've been posting them and 800x600 and they were fine </font>
The dimension of the photo does not in itself determine the file size.
When I say compress ... I'm saying that the file will still be 800x600, but the filesize will be compressed. Usually this option would be someplace in the Save As... dialog box.
   / picture size #5
If you're using Windows XP there's a free program available at "Powertows for Windows XP" on the MS website. I think it's called "Image Resizer". Haven't used it but have seen it recommended. You're striving to keep a decent pixel size for screen viewing but reduce the resolution to reduce file size the way I understand it.
   / picture size
Thanks Guys! I finally found it under JPEG I/O options, Compression Quality, I moved it to 40% and that did the trick.
Thanks again!
2018 FABRIQUE 20FT TRAILER (A52141)
2018 FABRIQUE 20FT...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
Army Semi Trailer (A50774)
Army Semi Trailer...
