Picture of my old 2210 4WD
   / Picture of my old 2210 4WD #1
matthew3120
Ashland Wisconsin
2007 John Deere 4120 4WD 12/12 Power revser
Here is a picture of my old 2210 siting at the John Deere dealer.Just took the picture after they put out on the lot.It has a 200CX loader,54C mmm,daul rear work lights, and 4 forwarding lights.It also has heavy duty 35 amp alternator and black heater.You would not believe the things I hauled and pulled with that tractor. Cars,trees,rocks you name it I pulled with that tractor. /forums/images/graemlins/frown.gifI will miss that tractor it was the best tractor. So heres the picture of my 2210.
Matthew3120
   / Picture of my old 2210 4WD #2
May I ask what you did to get a 35A alternator in your 2210?
At the time I brought the tractor I knew that I was going to put more lights on it so I had put the heavy duty 35A alternator in so I could run more lights or a 200 Gallon sprayer. /forums/images/graemlins/grin.gif
Matthew3120
   / Picture of my old 2210 4WD #5
There is a 35 amp alternator available for the 2210, and 4010 through 4115 series from JD, but it cost's $400.00 /forums/images/graemlins/shocked.gif Yes you read that right, $400.00
Yes they did it right there that night and delivered it the next day.The 2210 uses the same heavy duty alternator as a 4010 so they did not have to look much to get the alternator. /forums/images/graemlins/grin.gif
Matthew3120
Yeah $400.00 was alot but it makes a big differents when using the lights or powering the sprayer and I will tell you that the sprayer will drain a battery in quick hurry. It was money well spent. /forums/images/graemlins/grin.gif
Matthew3120
I traded my tractor in because I wanted something a little bit bigger.There was nothing wrong with my 2210 to tell you the truth I would have kept the 2210 if had money to put down on the new one.My 2210 ownly had 70 hrs on it and it was a 2004 model so it was not worked very hard.I tell you I do miss that tractor. Someday I will buy one again for playing around with. /forums/images/graemlins/grin.gif
Matthew3120
   / Picture of my old 2210 4WD #10
</font><font color="blue" class="small">( Here is a picture of my old 2210 siting at the John Deere dealer.Just took the picture after they put out on the lot.It has a 200CX loader,54C mmm,daul rear work lights, and 4 forwarding lights.It also has heavy duty 35 amp alternator and black heater.You would not believe the things I hauled and pulled with that tractor. Cars,trees,rocks you name it I pulled with that tractor. /forums/images/graemlins/frown.gifI will miss that tractor it was the best tractor. So heres the picture of my 2210.
Matthew3120
)</font>
I am confused, did you sell it back to them, consign it to them, or use it as a trade in? By the way is the dealer your refering to got an owner by the name of John? (in Mason?)
2015 John Deere 8245R MFWD Tractor (A53342)
2015 John Deere...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2014 RAM 4500 versa LIFT bucket truck (A52377)
2014 RAM 4500...
JOHM DEERE 1600 WAM LOT NUMBER 125 (A53084)
JOHM DEERE 1600...
2008 Volvo XC90 SUV (A51694)
2008 Volvo XC90...
