Picking up an 18' Aluma utility trailer tomorrow
   / Picking up an 18' Aluma utility trailer tomorrow #1
nikdfish
Veteran Member
Person Co. NC
John Deere 3038E & 1025R FILB
We have been talking about getting a trailer since we bought the 3038e in 2010 to use at the "farm" after moving back to NC. Then this year we picked up a 1025r FILB for use at the house & have already run into jobs where transportation of tractors/attachments between the two locations would be nice (tiller/backhoe/chipper/finish mower/etc). We have some things still going on in WV where it would be helpful to have something bigger than the 12x6 box trailer for hauling stuff between WV & NC. Based on the loads we have in mind & our tow vehicle (2008 F-150 supercab w/tow package), a 16+ foot tandem axle 7K utility made sense.
Our first impulse was to go with the best price we could find on something local, but reading some of the stories out there & considering our own experiences had us considering that what might be OK for the short run might bite us later with maintenance and repair issues.
We kicked around the alternatives, but finally decided to bite the bullet & go with something good for the long haul. From what we had looked at, the Aluma's seemed our best bet for payload, long life & value retention (even though the up front cost is about double). We first saw a 14 foot version in VA while traveling between WV & NC, but they didn't have anything larger that would be available in less than 6 weeks (plus we would end up having to pay VA tax + NC road use). I finally found what we were looking for in NC - a couple of hours away, but ready for pickup. Although 16' would have been adequate for 90% of our uses, it wasn't that much more to go with the 18' and it still only weighs 1100 lb., giving us a 5900 lb. max carrying capacity.
We changed the truck plates over to 13K weighted plates and are driving down tomorrow to pick up the Aluma 7818B. It has a 16' flat bed & 2' beavertail, slide out 5' ramps, front & side rails, stake pockets, 4 D-rings on the bed, 3500lb torsion axles w/brakes on both axles plus the breakaway kit. It also comes standard with rear leveling stands and 14" radials. I do think I will want to add some additional tie down points for chains after we get it home.
I'll try to remember to do the pics thing...
Nick
   / Picking up an 18' Aluma utility trailer tomorrow #2
Sounds like a nice trailer should be nice now and down the road years to come. :thumbsup:
   / Picking up an 18' Aluma utility trailer tomorrow #3
Make sure the load rating on the tires equal 3,500 lbs per axle. Also no mention of a spare. Get a matching one.
Also, why the 13K plates? In indiana the plates weight is just for the truck. Usuall 7K but on my F350 I have 12K. Then the trailer gets its own weight plate. My 3 trailers have a 7K, a 9K, and a 18K.
Chris
NC "weighted" plates go on the tow vehicle & have to cover vehicle weight plus max weight of trailer when a "property carrying" vehicle (i.e. truck) is the tow vehicle. The trailer plate is just registration - same for all trailer types. I've read of instances where enforcement types are writing tickets based on capacity of an empty trailer rather than actual weight on the road at time of stop. Seemed like relatively cheap insurance to cover worst case scenario - only about $20 more than the 11K (5600 actual for truck & contents, 5000 for towed load) that would be more realistic for us.
Good point about the spare. The tires on this trailer are rated for 1760 lb. each.
Nick
Pic as promised...
(Also remembered to pick up a mounted spare - they will ship me a fitted mount)
Nick
   / Picking up an 18' Aluma utility trailer tomorrow #6
Nice
Chris
   / Picking up an 18' Aluma utility trailer tomorrow #7
That is nice! Should last a long time and make towing pleasurable instead of hoping nothing breaks and we get there trips!!
   / Picking up an 18' Aluma utility trailer tomorrow #8
nikd, you're a lucky man!!!! I have trailer envy now lol. That's a super nice trailer, should last you MANY years, and the best part is after 20 yrs it won't be a rusty hulk of welded steel like my 16ft Diamond C Clipper utility trailer is now. Good luck with it!!
Finally took the first voyage with a tractor on board. We took the 1025r FILB 40 miles down to our daughter & SIL'S place to help move some dirt to let them pull their new Casita trailer around back when they bring it back from Texas.
I had added a Prodigy P2 brake controller to the wife's tow package equipped F-150 so that was good to go. 4 chains & some binders secured the tractor for the trip. No problems & no equipment casualties but the license plate got bent pretty good. The aluma is very low set with torsion axle suspension which makes for very easy load/unload and a very stabil tow but the darn license plate bracket is under the back edge of the beaver tail. Driveways end up tilting the trailer enough to pretty much bend the plate in half. Gonna have to come up with a better alternative.
This is my first trailer with brakes and I was very happy with how well the system works. There was no sense of being pushed by the trailer when braking even when braking hard to avoid a bozo who cut in and then immediately hit his brakes to turn off the road. I guess I had the power adjustment right as there was no lockup either.
Nick
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
2016 Freightliner M2 106 Medium Duty 26FT Box Truck (A51692)
2016 Freightliner...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A51692)
2014 GMC Sierra...
FAKE (A52472)
FAKE (A52472)
