Picked Up My 961...
   / Picked Up My 961... #1
Julian Mule
CA
I finally picked up this thing after a long wait...
I think she looks pretty good... not too pretty to use, but clean enough to keep the rust away. It's been converted to 12v and it had a unique combination of the pie weights and the ROPS. It needed tires, which I've already replaced. I will have some pics soon now that the rain is subsiding.
I really like the pie weights that I got with it as well.
http://i5.photobucket.com/albums/y178/Evilmaxxer/Tractor%20Stuff/961/PieWeights1.jpg
The front weight box holds the battery.
http://i5.photobucket.com/albums/y178/Evilmaxxer/Tractor%20Stuff/961/BatteryBox1.jpg
It has a set of rear-hydraulic remotes.
http://i5.photobucket.com/albums/y178/Evilmaxxer/Tractor%20Stuff/961/RearRemotes1.jpg
The hydraulic system is really strong. I picked up a 7ft woods deck with a 200lb guy standing on it and it didn't leak down at all with the tractor off. All 5 speeds work great, even though the tranny was stuck with I went to get it. We rocked it out of gear and it's been great ever since.
I need to thank Soundguy here for his valuable insights while I was looking around for one of these. I'll have some more pictures up later. Any comments or suggestions are welcome.
   / Picked Up My 961... #5
Morning Julian.
Looks like you got a heck of good idea...Congrats.
Owner took good care of her...are you considering maybe 1 or 2 tractor pull events?
Thomas said:
Morning Julian.
Thanks Thomas! It's funny to me that you ask me that... The guys at my tire place were going on and on about how good this tractor was for tractor pulls. I got it to do some specific work on my property. I never considered any pull events or anything... maybe after the work is done.
Do you do tractor pulls?
   / Picked Up My 961... #7
Evening Julian.
"Do you do tractor pulls?"
I did pull years back w/Farmall H.
Your 961 should be strong when sled weight starts bearing down...you'll have the power near the end of the pull,but the tractions we be the key....right weights w/tire pressure also ground condition...you won't stall the old girl that's for sure....onces you start pulling you'll enjoy it....give it shot...good time and good friends and whole lot of knowledge to be had.
   / Picked Up My 961... #8
Make sure that rear remotes hydraulic line is in good shape!! Where it's located I'd hate to be sitting there when it gives way. Nice looking tractor.
Any idea what those wheel weights weigh?
BTDT, thanks. I've got one new one on there and I'm getting another new one next week... I was thinking the same thing:D
They are either the "standard" weights that weigh around 30lbs each or they are the "heavy" weights that weigh 45lbs each. Total is supposed to be 800lbs including hardware for standard and just under 1200lbs for heavy with all hardware. I'm assuming they are the standard, because that was what was called for on everything except the 800/801.
   / Picked Up My 961... #10
Is that some kind of mirror/bar hanging off the front of the canopy? What did you finally decide on the cutter implement's original purpose on the front of the trailer?
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Toro Workman Cart (A50322)
Toro Workman Cart...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
Mini Forks (A50322)
Mini Forks (A50322)
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
