Physics question?
   / Physics question? #1
Shimon
Platinum Member
Sedro Woolley, WA
Kubota L3400 (gear driven)
I was thinking about this problem today and could use some help.
If you had a very solid sphere full of water and lowered the temperature so the water would (normally) freeze and the the sphere was as indestrucable as possible...would the water freeze since it has no room to expand? Or would the pressure just rise in the sphere and water stays in liquid form? I remember PV=T from school so I would guess that since volume is contant and temperature is decreased then pressure must go up. So, I would guess the water would not freeze. Am I right? (Sorry, but these kinds of things keep me up at night).
Thanks!
   / Physics question? #2
PV=NRT, as we always called pivnert, only applies to gasses and has no value here.
I think it would freeze solid but under great pressure. The intense pressure would seem to encourage the lower energy state of a solid.
   / Physics question? #3
I happens to me all the time, when I supercharge a beer in the freezer, then open it up. I'll get about one sip then it will freeze up /forums/images/graemlins/frown.gif now I rub the can on the back of my neck first. cools me off, and warms the beer a little /forums/images/graemlins/wink.gif
   / Physics question? #4
</font><font color="blue" class="small">( I happens to me all the time, when I supercharge a beer in the freezer, then open it up. I'll get about one sip then it will freeze up /forums/images/graemlins/frown.gif now I rub the can on the back of my neck first. cools me off, and warms the beer a little /forums/images/graemlins/wink.gif )</font>
Applied physics in it's truest form^
   / Physics question? #5
<font color="blue"> If you had a very solid sphere full of water and lowered the temperature so the water would (normally) freeze and the the sphere was as indestrucable as possible...would the water freeze since it has no room to expand? Or would the pressure just rise in the sphere and water stays in liquid form? </font>
It won't freeze
   / Physics question? #6
You need to look at the phase diagram
simple phase diagram
1 atm = 14.7 psi
complex phase diagram
1 Pa = 1.45x10e-4 psi
1 MPa = 10e6 Pa
Theoretical answer - if you could make your sphere infinitely rigid - it would freeze at ~10e9 Pa = 1.45 million psi
Practical answer - your sphere will either stretch a little or break allowing the water to freeze at more modest temperature & pressure
   / Physics question? #7
Will disolved gas content effect this any? ( lower that freezing pressure a tad? )
Soundguy
1983 Case 580D (A47477)
1983 Case 580D...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
2013 John Deere 350G LC Hydraulic Excavator (A53421)
2013 John Deere...
